cra1g321
- Oct 11, 2011
*** [SOLVED] ***
I currently have a HP Microserver running FreeNAS-8.2.0-RELEASE-p1-x64 (r11950)
with 4x 2TB drives in RAIDZ-1.
I access the volume (/mnt/volume1) from Windows (CIFS) and Linux (NFS)
I use a user account called 'user' for CIFS and a user account called 'cra1g321' for the NFS share. (both accounts are in the wheel group)
The shares permissions are setup so that when I'm connecting through NFS as cra1g321, i can read and write data, and when I connect through CIFS as user, i can only read the data.
I recently copied over a couple of Albums over the volume (/mnt/volume1/Music) when connected through NFS on my Linux OS, but when I get a permission error when i try to access the albums from Windows through CIFS.
This issue only seems to occur randomly, sometimes i copy music over and i access it fine then times, i cant. (may have something to do with me changing Linux distros now and again).
I tried to change the permissions for all the folders in the volume, under the Volume section of the webGUI, just by ticking the box beside 'Set permissions recursively' but when i do, i get a error saying 'An error Occurred' after a couple of minutes.
Here is a screenshot of the current permissions for the volume -
i read on another thread, that this may be a bug with 8.2 due to having lots of data on the volume, i have around 2.6TB of data in the volume. Also that 8.3 beta fixes this issue.
Is there anyway of fixing this or setting the permissions without upgrading to a beta ?
