Current setup:
3 HD ZFS RAIDz. I put all my folders and files at the top level (mnt/NAS). This way all the RAIDz space is available to all users. At the moment it is all guest access. I have both CiFS and NFS setup. The reason I am using NFS is that on my linux box, CiFS only downloads at 10 MB/sec, where NFS downloads 60-90 MB/sec. Via win7 its about 80 MB/s. I retried CiFS now to confirm these slow speeds, and it persists.
I would like to have some permissions on these folders, and exclude one user from deleting content.
Plan:
Set up following this tutorial permissions and shared folders between users.(thanks: http://protosd.blogspot.ca/2011/12/general-permissions-sharing-folders.html) without setting up private folders. I.e. Only setting up /mnt/storage/home/alpha-beta from his example.
A few pre-planning questions:
1. Do I need to move my /mnt/NAS data into the new folders /mnt/NAS/alpha-beta to setup these permissions? If I do, how do I ensure, if possible, my snapshots are moved into this new folder?
2. Am I able to use both CiFS and NFS when setting up this type of shares? The tutorial only uses CiFS and the speed is unacceptable via my linux box (I agree, if I could tune it or figure out the casuse, it would likely be a better setup).
Thanks for your thoughts before I give this a go. Option #3 is to reformat the RAIDz and start from scratch.
Kind regards,
FE
Current setup:
Plan:
Kind regards,
FE
