hey guys this is my first free nas build and I wanted to upload two build lists and get some feedback on them
1st build uses a
Norco 4U Rackmount Components RPC-4308 for the case
AsRock Rack X399D8A-2T
AMD Ryzen Threadripper 1920X
Crucial 16GB Single DDR4 2666 MT ecc ram
Noctua NH-D15 chromax.Black, 140mm Dual-Tower CPU Cooler
EVGA Super Nova 750 Ga, 80 Plus Gold Fully Modular, ECO Mode Compact 150mm Size, Power Supply
pros
"cheap" 12 core cpu
motherboard as 8 sata ports
type c port
dual 10g lan ports
8 ram slots so i can grow ram over time with a "cheap" 16 gig stick
cons
doesn't look like new models of the cpu will be made that will fit the motherboard after the second-gen
the motherboard is like $500
cant upgrade to 3rd gen unless I buy all new motherboard and cpu =$$$$
....just a note if I were to go this route I'm sure in 4 years when the Threadripper 2950X cpu comes down in price and I could upgrade to that and I dont see myself needing more. Threadripper 2950X should be around $300 and it will take me from a 11920x which is a 12cores/24 threads @ 3.5gh to a 16/32/3.5 or even a 24/48/3gh with the AMD Ryzen™ Threadripper™ 2970WX
Now build #2
motherboard = X470D4U2-2T
AMD Ryzen 5 3600X 6c/12t/3.8gh
Crucial 32GB Single DDR4 2666 MT ecc ram
pros
cheaper over all build
has more promising upgrade life I.e I can skip from the 5 to the 9 series cpu the AMD Ryzen 9 3900X 12-core, 24 threads @3.8 ghz which will double the cores and threads of the 3600x and should be around $200 when its time to upgrade.
an even better cpu could come later
cons
4 ram slots so I'm forced to invest in 32 single sticks if I want to add ram later and not waste money
not type c port
less sata ports I want to say it has 4 or 6 (not sure)
....More notes..... even though build 2 has a more promising future as of right right now the jump form the 5 series to the 9 would only put me at the starting point of build #1 when it comes to power and speed, granted that this would be builds #1 ceiling and AMD could come out with a series 9 cpu that is equal to the AMD Ryzen™ Threadripper™ 3970X @ 32/64/3.7ghz which I feel is a good upgrade over the AMD Ryzen™ Threadripper™ 3960X
now that all the specs are done here's what I'm hoping to achieve with the FreeNAS build
a back up of me and my partners' photography business
a time machine back up of at least 4 macs with at least 500 gigs of storage per device
my homes unifi camera footage
a windows 2019 server with a 500 gig hard drive I will mostly be using this as a testing dummy for work issues
a nextcloud jail to share files online with at least a 1tb of storage
I want to run the FreeNAS boot off of a M.2 drive fyi
I would like to use the other m.2 on the motherboard as a cache for the Nas to help with speed
Since the case has 8 bays I'm thinking I want to run a raidz2 but thanks to this link
https://www.ixsystems.com/blog/zfs-pool-performance-2/# I'm not sure if I should run a raidz3 instead
ps. any help with that would be appreciated.
sigh so what do you think? Option 1 or 2?
