Chris Moore
- May 2, 2015
How is this working? Did you upgrade to FreeNAS 11.2 - RELEASE yet?
If you mean DisplayLink, forget about that. It requires a driver.think a HDMI to USB-C might work instead of gettinga GPU?
It's not always possible. Bifurcation requires some hardware support, as I understand it.I thought about the GPU occupying the x16 slot. IIRC there are some GPUs that don't need all 16 lanes (or whatever the x16 stands for) and one could use a PCI e riser to convert a single x16 slot into for example two x8 slots... Edit: and put a GPU into one of them and other stuff into the other
Sent from my phone
If the question is addressed to me, then yes.How is this working? Did you upgrade to FreeNAS 11.2 - RELEASE yet?
Does it happen no matter what m.2 slot you try?I need to address the NVME issue though. Any thought on that?
I have tried only one of the three M.2 slot. It is by no means a complete and thorough test.Does it happen no matter what m.2 slot you try?
Sent from my phone
Which of the two coolers have used?quick update, I put everything together and everything seems to be running great.
Sent from my phone
I don't think you need to do much overclocking.Noctua NH-U14S TR4-SP3 Premium-Grade 140mm (x2 fan)
works great - that being said I am not doing any overclocking. CPU temp hangs around 35 C for the time being.
if you enable javascript you can click 'show my system' to see what I have.
Sent from my phone
Do you use the "-p" option for shutdown?@newfreenas @Apollo...
The only thing I experienced is the shutdown bug that was mentioned in the beginning of the thread, initiating a shutdown from the CLI does not shut down the computer completely.
Have you found a solution or workaround to this?
Thanks!
Yeang
shutdown -p nowHi,Do you use the "-p" option for shutdown?
Like this?
shutdown -p now
When I used the Linux "shutdown -h now", FreeNAS did no power off.
