Getting the message in the above when attempting to do a portmaster update inside of my jails.
The Jail: 11.0-STABLE
FreeNAS Version: FreeNAS-11.0-U4 (54848d13b)
In order to help, we need to see the entire message, ideally with the messages before and after it for context. They should be logged in /var/log/messages.
# portmaster -a
===>>> Gathering distinfo list for installed ports
===>>> Starting check of installed ports for available updates
===>>> Launching child to update plexmediaserver-plexpass-1.10.0.4523 to plexmediaserver-plexpass-1.10.1.4561
===>>> All >> plexmediaserver-plexpass-1.10.0.4523 (1/1)
===>>> Currently installed version: plexmediaserver-plexpass-1.10.0.4523
===>>> Port directory: /usr/ports/multimedia/plexmediaserver-plexpass
===>>> Launching 'make checksum' for multimedia/plexmediaserver-plexpass in background
===>>> Gathering dependency list for multimedia/plexmediaserver-plexpass from ports
===>>> Initial dependency check complete for multimedia/plexmediaserver-plexpass
===>>> Returning to update check of installed ports
===>>> All >> (1)
===>>> The following actions will be taken if you choose to proceed:
Upgrade plexmediaserver-plexpass-1.10.0.4523 to plexmediaserver-plexpass-1.10.1.4561
===>>> Proceed? y/n [y] y
===>>> Starting build for ports that need updating <<<===
===>>> Launching child to install multimedia/plexmediaserver-plexpass
===>>> All >> multimedia/plexmediaserver-plexpass (1/1)
===>>> Starting check for build dependencies
===>>> Dependency check complete for multimedia/plexmediaserver-plexpass
===> Cleaning for plexmediaserver-plexpass-1.10.1.4561
/!\ ERROR: /!\
Ports Collection support for your FreeBSD version has ended, and no ports are
guaranteed to build on this system. Please upgrade to a supported release.
No support will be provided if you silence this message by defining
ALLOW_UNSUPPORTED_SYSTEM.
*** Error code 1
Stop.
make[1]: stopped in /usr/ports/multimedia/plexmediaserver-plexpass
*** Error code 1
Stop.
make: stopped in /usr/ports/multimedia/plexmediaserver-plexpass
===>>> make build failed for multimedia/plexmediaserver-plexpass
===>>> Aborting update
===>>> Update for multimedia/plexmediaserver-plexpass failed
===>>> You can restart from the point of failure with this command line:
portmaster <flags> multimedia/plexmediaserver-plexpass
This command has been saved to /tmp/portmasterfail.txt
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
