After shutdown for a few days - black screen when booting
zimon
I shut down my FreeNAS for a few days and when I started it again I was not able to connect to any of my web interfaces. Also SSHing into it was not possible.
So I plugged in a monitor and keyboard and I saw a black screen with a blinking cursor.
When I restart the FreeNAS after the bios when the boot process starts the black screen with the blinking cursor appears again.
I have my boot usb drive mirrored but even when the drive is dead, shouldn't there be something like "can't read boot device" be displayed?
What should I do?
Jailer
Not strong, but bad
Replace your boot device(s), reinstall and upload a copy of your saved config file.
You do have a copy of your config files saved correct?
zimon
I solved it, for some reason there was another bootdevice selected in the bios. How can that happen?
MrToddsFriends
Documentation Browser
Maybe a firmware bug. Would you like to tell us which hardware (motherboard) you are using?
Redcoat
Could you have chosen a temporary one on the previous boot?
zimon
I did not mess with the boot device at all.
I have a HP Proliant Microserver but I cannot tell you the exact motherboard (I don't have access to it right now)
