cmh
- Jan 7, 2013
Couple weeks/months ago I had questions about replacing a failed boot USB that was part of a two-drive mirror - was trying to figure out which one had failed. Well, I figured it out and replaced it, and it resilvered. I had asked an aside about making sure it was bootable, didn't get an answer but didn't really push it.
Well, tonight I upgraded to the latest version, and the system never came back. Had to run out to the shop and turn on the monitor and see the dreaded blinking cursor on the black screen. Power cycled the system and it went through the BIOS back to the blinking cursor. Tried again just to make sure, then got brave and pulled the newly replaced boot drive. System booted, and I put the drive back in so it'd be present for the mirror once the system was booted.
As the system was booting, I noticed it was doing a grub-install on da1 (the new drive) and then on da0. (the existing drive) Once it was done with that, it rebooted, and booted fine with both drives installed.
So, is there a step that I skipped when I replaced the failed drive, or did I have to manually run the grub-install?
(Yes - I searched the forums and found a bunch of hits that weren't related to OS mirroring and hits that were relevant were not newer than almost three years ago.)
