michael.keller
- Feb 10, 2017
Hi all,
I'm having some problems with my FreeNas server and I'm not sure how to fix this. After a reboot I can only access my AFP-share as read-only. I've already tried:
- reboot ;)
- delete the AFP-Share and add a new one with the same path
- changed the default file and folder permissions so everyone should have read/write/execute abilities
- change the volume permissions so everyone should have access (with recursively checked)
If I try to delete a file on the share, the console says the following:
I couldn't find any hint how to run a database recovery.
I'm running FreeNas on a Supermicro Board (I think it's an A1SAi-2550 with an Intel Atom C2550 @ 2.40GHz) with 32GB of ECC-RAM. My volume is a Raid-Z2 with 6 x 1TB WD Red Drives.
Any help is appreciated. If you need more information, please ask.
Thanks!
Michael
- reboot ;)
Feb 10 13:23:24 misami_fileserver afpd[14972]: Login by mk (AFP3.4) Feb 10 13:23:24 misami_fileserver cnid_dbd[14973]: error deleting key/value from cnid2.db: Invalid argument Feb 10 13:23:24 misami_fileserver cnid_dbd[14973]: dbd_delete: Unable to delete entry for CNID 592 Feb 10 13:23:24 misami_fileserver afpd[14972]: Reopen volume /mnt/volume/server using in memory temporary CNID DB. Feb 10 13:23:24 misami_fileserver cnid_dbd[14973]: error closing database name.db: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery Feb 10 13:23:24 misami_fileserver cnid_dbd[14973]: error closing database didname.db: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery Feb 10 13:23:24 misami_fileserver cnid_dbd[14973]: error closing database devino.db: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery Feb 10 13:23:24 misami_fileserver cnid_dbd[14973]: error closing database cnid2.db: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery Feb 10 13:23:24 misami_fileserver cnid_dbd[14973]: error closing DB environment: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery
Thanks!
Michael
