I can't seem to find a straight answer to this. All my searching thus far has turned up results from people wanting to convert an existing RAID0 to a RAID10 while retaining the same number of disks.
What I want to do is create a RAID0 array with 2 disks, with a view to add a further 2 disks at a later date creating a RAID10. I want redundancy, NOT extra storage.
I just want to know whether this is possible, I haven't set up anything yet, haven't even built a PC to house all this. I have 2 disks ready to go, they're just expensive and I can't afford to purchase another 2 right now.
In my head it seems logical enough, I've learned that these things are rarely as easy as they sound!
Cheers!
*edit - I'm thinking in RAID terms when perhaps I should be better off thinking in RAID-Z. Now I'm confused.
I will be starting out with a "stripe" setup, with a view to doubling the disks and moving to a RAID-Z2 setup. Hopefully without having to move everything elsewhere when the time comes to add the second lot of disks.
edit 2 - Been playing with FreeNAS in vmware, it seems that the only way of doing what I want to achieve is by starting with a mirror and then extending that with another new mirror. Is this correct or can I do it as I originally proposed? I might be able to get by for a while with half the storage space, but would rather not if at all possible.
Cheers again!
Cheers!
Cheers again!
