Add support for Energenie UPS
LarsR
you could check with nut-scanner -U in shell which driver it expects. If it's a generic ups driver like "usbhid-ups" you can use any available driver from the drop down menu
I try a lot of drivers, but unsuccessfully, even nut-scanner gives me this info:
[nutdev1]
driver = "nutdrv_atcl_usb"
port = "auto"
vendorid = "0001"
productid = "0000"
product = "ATCL FOR UPS"
serial = "ATCL FOR UPS"
vendor = "ATCL FOR UPS"
bus = "001"
LarsR
That one is really not included, but i found a website that states that it could be compatible with the nutdrv_qx driver which is included in truenas scale. The First driver in the list i found was "Atlantis Land ups 2 Hostpower851 (A03-HP851) USB (nutdrv_qx)" maybe give this one a try
I setup EUROCASE ups 2 EA200N 2000VA USB (nutdrv_qx) and seems it's works. diamond started, an no error messages.
Could you please help me, how I can read data from UPS, to check if everything is OK?
Ed
LarsR
you'd have to use the shell and use the upsc command
example: upsc upsuser@localhost should give you an output of the ups's status. obviously replace upsuser with the user you set up.
thank you very much... now I see it's works:
ups.beeper.status: enabled
ups.delay.shutdown: 30
ups.delay.start: 180
ups.firmware: V4.00
ups.load: 6
ups.productid: 0000
ups.status: OL
ups.temperature: 35.0
ups.type: offline / line interactive
ups.vendorid: 0001
