you could check with nut-scanner -U in shell which driver it expects. If it's a generic ups driver like "usbhid-ups" you can use any available driver from the drop down menu
That one is really not included, but i found a website that states that it could be compatible with the nutdrv_qx driver which is included in truenas scale. The First driver in the list i found was "Atlantis Land ups 2 Hostpower851 (A03-HP851) USB (nutdrv_qx)" maybe give this one a try
you'd have to use the shell and use the upsc command
example: upsc upsuser@localhost should give you an output of the ups's status. obviously replace upsuser with the user you set up.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
