Add raid card after configuration
striker79
That seems easy enough. I believe I am seeing the integrated sas controller on the mb though (SAS2301). How would I select the 9211-8i?
Mirfster
BTW, you "Paste" into Putty by simply Right-Mouse click... Not the normal "CTRL+V" you would use in Windows. Funny because, you can use "CRTL-C" to copy whatever you choose to highlight with the mouse...
Mirfster
striker79
Yeah. I realized that just after I tried control v. lol.
Any idea about the 2301 controller that I mentioned above? Not sure how to select the LSI 9211-8i
striker79
Adapter Selected is a LSI SAS: SAS2308_1(D1)
Num Ctlr FW Ver NVDATA x86-BIOS PCI Addr
0 SAS2308_1(D1) 20.00.04.00 14.01.30.16 07.39.00.00 00:02:00:00
1 SAS2008(B2) 19.00.00.00 11.00.00.08 07.37.00.00 00:07:00:00
Mirfster
Yep, since you have two controllers and you want to work with the "SAS2008(B2)" one, you would leverage the "-c #" switch.
Since the one you want is number 1, your commands would now be this:
  • sas2flash -o -c 1 -listsasadd
    • So you can copy the address (just in case)
  • sas2flash -o -c 1 -f 2118it.bin -b mptsas2.rom
striker79
That worked! Thank you times a million! I'll keep updating as I troubleshoot to see if the cables are causing the problems.
striker79
Thank you! After restarting, all errors look to have been correcting, but i will know for sure after a scrub.
striker79
Just an update. After installing the new card and cables, and upgrading the firmware on the raid card, I have not seen any errors.
Marcet
Nice (y)
