SOLVED add new hard drive not show after install
zatan
When I install TrueNAS I have 3 HHD, I added another HHD after installing but the forth drive is not detected in TrueNAS core 12 u3. I can see 4 in the BIOS.
camcontrol devlist not show the 4th disk.
That's going to need attention before anything will work in the middleware.
What do you see from dmesg | grep da ?
zatan
dmesg | grep da
It shows ada0,1,2
still dont see the 4 drive on that ada3
FreeBSD is a registered trademark of The FreeBSD Foundation.
efirtc0: registered as a time-of-day clock, resolution 1.000000s
atrtc0: registered as a time-of-day clock, resolution 1.000000s
orm0: <ISA Option ROMs> at iomem 0xc0000-0xcffff,0xda000-0xdafff,0xdb000-0xdbfff pnpid ORM0000 on isa0
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <ST500LM000-1EJ162 DEM9> ACS-2 ATA SATA 3.x device
ada0: Serial Number W763AZ2C
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 476940MB (976773168 512 byte sectors)
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <ST500LM000-1EJ162 DEM9> ACS-2 ATA SATA 3.x device
ada1: Serial Number W763B0H9
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 476940MB (976773168 512 byte sectors)
ses0: ada0 in 'Slot 00', SATA Slot: scbus0 target 0
ada2 at ahcich3 bus 0 scbus3 target 0 lun 0
ada2: <ST500LM000-1EJ162 DEM9> ACS-2 ATA SATA 3.x device
ada2: Serial Number W76395BN
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 476940MB (976773168 512 byte sectors)
ses0: ada1 in 'Slot 01', SATA Slot: scbus1 target 0
ses0: ada2,pass2 in 'Slot 03', SATA Slot: scbus3 target 0
da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
da0: < PMAP> Removable Direct Access SPC-4 SCSI device
da0: Serial Number 070A6952F22AF379
da0: 40.000MB/s transfers
da0: 15296MB (31326208 512 byte sectors)
da0: quirks=0x2<NO_6_BYTE>
da1 at umass-sim1 bus 1 scbus7 target 0 lun 0
da1: <Generic- Compact Flash 1.00> Removable Direct Access SCSI device
da1: Serial Number 20100818841300000
da1: 40.000MB/s transfers
da1: Attempt to query device size failed: NOT READY, Medium not present
da1: quirks=0x2<NO_6_BYTE>
da2 at umass-sim1 bus 1 scbus7 target 0 lun 1
da2: <Generic- SM/xD-Picture 1.00> Removable Direct Access SCSI device
da2: Serial Number 20100818841300000
da2: 40.000MB/s transfers
da2: Attempt to query device size failed: NOT READY, Medium not present
da2: quirks=0x2<NO_6_BYTE>
da3 at umass-sim1 bus 1 scbus7 target 0 lun 2
da3: <Generic- SD/MMC 1.00> Removable Direct Access SCSI device
da3: Serial Number 20100818841300000
da3: 40.000MB/s transfers
da3: Attempt to query device size failed: NOT READY, Medium not present
da3: quirks=0x2<NO_6_BYTE>
da4 at umass-sim1 bus 1 scbus7 target 0 lun 3
da4: <Generic- M.S./M.S.Pro/HG 1.00> Removable Direct Access SCSI device
da4: Serial Number 20100818841300000
da4: 40.000MB/s transfers
da4: Attempt to query device size failed: NOT READY, Medium not present
da4: quirks=0x2<NO_6_BYTE>
Waiting (max 60 seconds) for system thread `bufdaemon' to stop... done
Waiting (max 60 seconds) for system thread `bufspacedaemon-2' to stop... done
Waiting (max 60 seconds) for system thread `bufspacedaemon-3' to stop... done
Waiting (max 60 seconds) for system thread `bufspacedaemon-0' to stop... done
Waiting (max 60 seconds) for system thread `bufspacedaemon-4' to stop... done
Waiting (max 60 seconds) for system thread `bufspacedaemon-5' to stop... done
Waiting (max 60 seconds) for system thread `bufspacedaemon-6' to stop... done
Waiting (max 60 seconds) for system thread `bufspacedaemon-1' to stop... done
ses0: ada2 in 'Slot 03', SATA Slot: scbus3 target 0
How is it attached to the system?
You say it's showing up as a disk in the BIOS? does it have the correct size?
Is there a possibility that you have a SATA port that's shared with an M.2 interface and you're using the M.2?
zatan
its is connected on the sata port of the motherboard. All hhd is connected to the same way.
is there anything i have to do besides shutdown, add hhd, bootup?
zatan
Find out it was a bad hhd. replaced with a another hhd and its working.
