I just upgraded my NAS box to 8.0.4 release. Everything works just fine. However, today I was trying to add an external USB WD HHD (3TB) onto my NAS box. When I went into the web GUI, I can see the new HHD. However, when I tried "import volume" and clicked okay, I got an error, saying "some error occurs when labeling the volume" (may not exactly the wording, but similar).
My box is based on an old DELL Dimension 4700 PC and 32 bit OS, 2GB SDRAM. I'm wondering: could it be either my hardware system or FreeNAS 8 32-bit doesn't support 3TB hard drive (no partition, just one drive)? Do I have to partition my 3TB drive to 2 or more partitions for it to be able to import?
Any suggestion or advice will be appreciated!
thanks.
Hazeline
thanks.
Hazeline
