Add external HDD without loosing data on it.
MrDrizz
So as I have a new install I need to put all my backed up files back on the server. These files are on an external HDD.
How to I add the external drive so I can access the files and transfer them back onto the server? I've plugged it in and it shows up in 'view disks' as da1
The server is a HP proliant micro server.
Z300M
How is that external HDD formatted?
Yatti420
http://doc.freenas.org/index.php/Volumes#Importing_Volumes
FreeNAS® supports the import of disks that have been formatted with UFS, NTFS, MSDOS, or EXT2.
Maybe mount it on a compatible computer etc and transfer the files to the NAS.. I thought about a linux jail but not sure if it comes with disk support? Easier to just mount it on a known good computer and transfer..
MrDrizz
Thanks. so I can add the drive as it's ext4. So will have to transfer the files manually from a PC over the network.
