Access Based Share Enumeration
Agung
I've case with FN 11.1 U6 installed on HP Proliant ML310e server.
I configure SMB share with Access based share enumeration tick on one of my sharing folder but unfortunately when I access my sharing folder use other pc on the network I can still see other folder that I don't have permission on it.
anodos
Sambassador
Access Based Share Enumeration depends on the "Share ACL", which you manage through "Computer Management" on a Windows workstation.
Agung
Thanks for reply @anodos : I can't delete everyone permission from the windows client thats say "I'm not permit delete from this windows client" even I login as administrator for that client.
I think there is a bug or something like that because if I create new dataset under my parent share always auto adding "everyone permission"
anodos
Sambassador
Adding "everyone" was a design decision. You need to change the permissions of the new dataset (through the webui) so that it is owned by your admin user/group. Then the user will be able to change permissions.
Agung
Back to access based share enumeration, do you have trial or guidance document for successfully testing that feature?
thanks
