Having some trouble currently sharing a sub folder in a parent folder that has no permissions. It should allow access direct to that folder (via UNC/shortcut etc) without any other settings according to some, yet others say you need the traverse permissions.
In my own testing I need traverse on the parent, and this works fine when sharing from a windows machine, but not from freenas (that has joined the domain). I've scaled back the options like group for testing currently by using a specific user to avoid any problems with nested groups with no luck.
As an example...
Parent (R/W for all users)
----Dir1 (no inherit, r/w for UserA)
--------SubDir1 (inherit + r/w for UserB)
----Dir2 (no inherit, r/w for UserB)
UserA cannot see/access Dir2 as expected, and UserB cannot see/access Dir1 as expected - thus access based enumeration seems to be on, even though docs says its default off? and its not on in the freenas config.
What we want is UserB to access a single folder inside a folder that is normally only for UserA, without having full access to everything.
In a windows server, setting r/w on SubDir1 is not enough, but putting Traverse on Dir1 allows UserB direct access to SubDir1 - this is okay.
Similar setting on as FreeNAS share does not work, we have even tried putting Traverse+List Folder on Dir1 and UserB cannot even browse through the folders either.
As an example...
