I had this prob on 8.2.0 beta1: GEOM: da0s1: geometry does not match label (16h,63s !=255h,63s)
Now I upgraded to 8.2.0 beta2, my NAS is working again but I lost all my volumes and settings.
All my Photos since 199x were on this NAS, what can I do to restore my stuff.
Thanks a lot for your help
Try this:
1. Enable SSH and login to your NAS.
2. Look in /data for a file called "freenas-v1.db.bak." Note the file date.
3. Use SCP to copy this file to somewhere safe (i.e. other than your NAS)
4. Reinstall the version of FreeNAS that you had installed during the date of the above file (assuming it is prior to your using the betas).
5. Make a copy of the downloaded freenas-v1.db.bak to freenas-v1.db
6. Login to the web gui and:
a) Click System -> Settings -> General
b) Click Upload Config
c) Browse to the freenas-v1.db file and click Update.
AND STOP USING BETA SOFTWARE WITH YOUR IMPORTANT DATA
