Oko
- Nov 30, 2013
I am deliberating what to do about one of my older file servers having 2xXeon 5120 2GB or RAM ( I think I can come up with some older module) and most importantly hardware RAID card 3ware 9550SX. My original plan was to rebuilt the machine as a backup storage using vanilla FreeBSD 10.1, hardware RAID and UFS until I saw this
Obviously I need new battery pack which surprisingly cost over $50 (any suggestions where can I find cheaper will be appreciated). The truth of the matter I don't want to use it as a hardware raid since it doesn't support RAID 6. However I found that it support JBOD mode of course.
My question is if I use this hardware RAID card in JBOD mode can I safely remove batter pack since RAID card will no longer be cashing things? If that is the case I might be better off investing little money in memory and running ZFS on a shoe string. Any advise comment is highly appreciated.
3w-9xxx: scsi0: AEN: INFO (0x04:0x0055): Battery charging started:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0056): Battery charging completed:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0053): Battery capacity test is overdue:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0051): Battery health check started:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0052): Battery health check completed:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0055): Battery charging started:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0056): Battery charging completed:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0053): Battery capacity test is overdue:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0055): Battery charging started:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0056): Battery charging completed:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0053): Battery capacity test is overdue:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0055): Battery charging started:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0056): Battery charging completed:. 3w-9xxx: scsi0: AEN: INFO (0x04:0x0053): Battery capacity test is overdue:. 3w-9xxx: scsi0: WARNING: (0x06:0x002C): Unit #1: Command (0x2a) timed out, resetting card. 3w-9xxx: scsi0: AEN: INFO (0x04:0x005E): Cache synchronization completed:unit=1. 3w-9xxx: scsi0: AEN: WARNING (0x04:0x0032): Spare capacity too small for some units:spare unit=2, RAID unit=0.
