[root@rosalba] /var/log# cat dmesg.yesterday
Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.1-STABLE #0 r+0537213: Mon May 27 00:49:28 PDT 2013
root@build.ixsystems.com:/tank/build/nightlies/2013-05-27/os-base/amd64/tank/build/nightlies/2013-05-27/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Xeon(R) CPU E5405 @ 2.00GHz (2000.04-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x10676 Family = 0x6 Model = 0x17 Stepping = 6
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0xce33d<SSE3,DTES64,MON,DS_CPL,VMX,TM2,SSSE3,CX16,xTPR,PDCM,DCA,SSE4.1>
AMD Features=0x20100800<SYSCALL,NX,LM>
AMD Features2=0x1<LAHF>
TSC: P-state invariant, performance statistics
real memory = 4294967296 (4096 MB)
avail memory = 4093595648 (3903 MB)
Event timer "LAPIC" quality 400
ACPI APIC Table: <PTLTD APIC >
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.0> irqs 0-23 on motherboard
ioapic1 <Version 2.0> irqs 24-47 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
acpi0: <SMCI SMCISLP2> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 2.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 0.0 on pci1
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 0.0 on pci2
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> at device 0.0 on pci3
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> at device 0.2 on pci3
pci5: <ACPI PCI bus> on pcib5
pcib6: <ACPI PCI-PCI bridge> irq 18 at device 2.0 on pci2
pci6: <ACPI PCI bus> on pcib6
em0: <Intel(R) PRO/1000 Network Connection 7.3.7> port 0x2000-0x201f mem 0xda120000-0xda13ffff,0xda100000-0xda11ffff irq 18 at device 0.0 on pci6
em0: Using an MSI interrupt
em0: Ethernet address: 00:30:48:33:84:9e
em1: <Intel(R) PRO/1000 Network Connection 7.3.7> port 0x2020-0x203f mem 0xda160000-0xda17ffff,0xda140000-0xda15ffff irq 19 at device 0.1 on pci6
em1: Using an MSI interrupt
em1: Ethernet address: 00:30:48:33:84:9f
pcib7: <ACPI PCI-PCI bridge> at device 0.3 on pci1
pci7: <ACPI PCI bus> on pcib7
em2: <Intel(R) PRO/1000 Legacy Network Connection 1.0.5> port 0x3000-0x303f mem 0xda080000-0xda09ffff,0xda000000-0xda03ffff irq 24 at device 1.0 on pci7
em2: Ethernet address: 00:1b:21:34:71:68
em3: <Intel(R) PRO/1000 Legacy Network Connection 1.0.5> port 0x3040-0x307f mem 0xda0a0000-0xda0bffff,0xda040000-0xda07ffff irq 25 at device 1.1 on pci7
em3: Ethernet address: 00:1b:21:34:71:69
pcib8: <ACPI PCI-PCI bridge> at device 4.0 on pci0
pci8: <ACPI PCI bus> on pcib8
3ware device driver for 9000 series storage controllers, version: 3.80.06.003
twa0: <3ware 9000 series Storage Controller> port 0x4000-0x40ff mem 0xd8000000-0xd9ffffff,0xda300000-0xda300fff irq 16 at device 0.0 on pci8
twa0: INFO: (0x04: 0x0053): Battery capacity test is overdue:
twa0: INFO: (0x15: 0x1300): Controller details:: Model 9690SA-4I, 128 ports, Firmware FH9X 4.06.00.004, BIOS BE9X 4.05.00.015
pcib9: <ACPI PCI-PCI bridge> at device 6.0 on pci0
pci9: <ACPI PCI bus> on pcib9
pci0: <base peripheral> at device 8.0 (no driver attached)
pcib10: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
pci10: <ACPI PCI bus> on pcib10
uhci0: <Intel 631XESB/632XESB/3100 USB controller USB-1> port 0x1800-0x181f irq 17 at device 29.0 on pci0
usbus0 on uhci0
uhci1: <Intel 631XESB/632XESB/3100 USB controller USB-2> port 0x1820-0x183f irq 19 at device 29.1 on pci0
usbus1 on uhci1
uhci2: <Intel 631XESB/632XESB/3100 USB controller USB-3> port 0x1840-0x185f irq 18 at device 29.2 on pci0
usbus2 on uhci2
ehci0: <Intel 63XXESB USB 2.0 controller> mem 0xda700400-0xda7007ff irq 17 at device 29.7 on pci0
usbus3: EHCI version 1.0
usbus3 on ehci0
pcib11: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci11: <ACPI PCI bus> on pcib11
vgapci0: <VGA-compatible display> port 0x5000-0x50ff mem 0xd0000000-0xd7ffffff,0xda400000-0xda40ffff irq 18 at device 1.0 on pci11
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <Intel 63XXESB2 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x1860-0x186f at device 31.1 on pci0
ata0: <ATA channel> at channel 0 on atapci0
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_button0: <Power Button> on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
fdc0: <floppy drive controller> port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on acpi0
ppc0: <Parallel port> port 0x378-0x37f,0x778-0x77f irq 7 drq 3 on acpi0
ppc0: SMC-like chipset (ECP/EPP/PS2/NIBBLE) in COMPATIBLE mode
ppc0: FIFO with 16/16/9 bytes threshold
ppbus0: <Parallel port bus> on ppc0
lpt0: <Printer> on ppbus0
lpt0: Interrupt-driven port
orm0: <ISA Option ROMs> at iomem 0xc0000-0xcafff,0xcb000-0xccfff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.19
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe00027cf700 with IPv6 initialized (100409)
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <Intel> at usbus2
uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <Intel> at usbus3
uhub3: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
GEOM_RAID5: Module loaded, version 1.1.20110927.40 (rev 00ce00e5abb4)
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
uhub3: 6 ports with 6 removable, self powered
ugen3.2: <TSSTcorp> at usbus3
umass0: <TSSTcorp USB Mass Storage Device, class 0/0, rev 2.00/6.14, addr 2> on usbus3
ugen3.3: <Kingston> at usbus3
umass1: <Kingston DataTraveler G3, class 0/0, rev 2.00/1.00, addr 3> on usbus3
ugen3.4: <Unknown> at usbus3 (disconnected)
da0 at twa0 bus 0 scbus0 target 0 lun 0
da0: <AMCC 9690SA-4I DISK 4.06> Fixed Direct Access SCSI-5 device
da0: 100.000MB/s transfers
da0: 14304960MB (29296558080 512 byte sectors: 255H 63S/T 1823626C)
da1 at umass-sim1 bus 1 scbus3 target 0 lun 0
da1: <Kingston DataTraveler G3 1.00> Removable Direct Access SCSI-2 device
da1: 40.000MB/s transfers
da1: 3817MB (7818184 512 byte sectors: 255H 63S/T 486C)
cd0 at umass-sim0 bus 0 scbus2 target 0 lun 0
cd0: <TSSTcorp CDDVDW SE-S084C TS01> Removable CD-ROM SCSI-0 device
SMP: AP CPU #2 Launched!
cd0: 40.000MB/s transfers
cd0: Attempt to query device size failed: NOT READY, Medium not present - tray open
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
Timecounter "TSC" frequency 2000040642 Hz quality 1000
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
twa0: INFO: (0x04: 0x000C): Initialize started: unit=0
twa0: INFO: (0x04: 0x0007): Initialize completed: unit=0
twa0: INFO: (0x04: 0x0029): Verify started: unit=0
