32-bit VS 64-bit FreeNAS 8.2.x?
WrenchGuy
My apologies if this has been covered elsewhere, but my search didn't find anything...
In regards to FreeNAS 8.2.x, other than ZFS and more RAM, is there anything that 64-bit offers over 32-bit?
If there is another thread for this, please link me. :)
joeschmuck
Old Man
Stability, More user testing. If you will not be using ZFS then 32-bit should be fine. If you plan to use ZFS then you really should go with 64-bit and 6GB RAM. Plug-Ins are a new feature with 8.2.x and will use more RAM depending what you load (when they work) but that is a RAM issue and your RAM will be limited to ~3GB with a 32-bit system.
