2FA With Authy
ByerRA
Is there any plans on adding 2FA to FreeNAS? I would like to have the ability to have 2FA with Authy for users using the web management interface or SSH.
SSH with Public Key authentication generally implies two-factor authentication, since you need a passphrase to decrypt the key you sign the server's challenge with.
sweeze
Using Duo works; integration is simple and push authentication to mobile phone is much nicer than generating codes.
You'll have to explain that much better, because what you're suggesting does not make sense.
...assuming that key is encrypted in the first place, and there's really no way for the FreeNAS admin to enforce that.
Which part do you not understand? I'm using Duo Security for MFA.
And how does that integrate with FreeNAS?
The really big issue is with root's SSH access. Regular users are a whole different matter - they probably shouldn't have SSH access at all.
I am trying to set this up, I have used duo on other systems, but keep failing because It seems i do not have a compiler installed. When I run pkg isntall gcc, I get the following error. pkg: archive_read_open_filename(//usr/ports/packages/All/mpfr-3.1.3_1.txz): Failed to open '//usr/ports/packages/All/mpfr-3.1.3_1.txz
I have no idea how to fix this, or get a different compiler installed. Can you give me a nudge in the right direction of fixing this?
Use the FreeBSD pkg for duo: https://www.freshports.org/security/duo/
Trying to get a functional compiler and libraries on your FreeNAS dataset is probably a bad idea.
I am going to shock you here, but I am a giant noob with freenas. I am now trying to figure out how to use freshports with freenas. But i also have a potentially related question. Should I be installing duo in a jail, or on base freenas?
I don't see how that will provide 2fa for ssh/sftp?
I don't see any way to do that on FreeNAS without breaking a lot of rules. I also don't see any reason to use 2FA for SSH or SFTP, when public key authentication is an option instead.
Not to sound like a dick, but i guess I should be looking for help from one of the people who tackled this problem earlier. As for the need, again, being heavily invested in 2fa across other systems, this is easier to get access to. Plus it allows access when I am not at my primary machine.
Thanks though.
