[2019]: Network tunables for 10G NICs
Wanderhoden.
Hey there,
I found some old threads regarding this topic, but they seem to be outdated / deliver no essential information.
After upgrading to 10 gbe recently I did observe that the network with iperf3 was quite slow. I just peaked at around 4 GBit/s on both sites.
On my windows machine (Asus XG-100C) I was able to do some tuning (buffer increasement, jumboframes 9k byte,...)
Now the iperf looks not perfect, but a lot better from the clients side:
iperf3 - Windows to FreeNAS
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.00   sec   805 MBytes  6.75 Gbits/sec
[  5]   1.00-2.00   sec   882 MBytes  7.40 Gbits/sec
[  5]   2.00-3.00   sec   907 MBytes  7.61 Gbits/sec
[  5]   3.00-4.00   sec   913 MBytes  7.66 Gbits/sec
[  5]   4.00-5.00   sec   909 MBytes  7.63 Gbits/sec
[  5]   5.00-6.00   sec   845 MBytes  7.09 Gbits/sec
[  5]   6.00-7.00   sec   868 MBytes  7.28 Gbits/sec
[  5]   7.00-8.00   sec   895 MBytes  7.51 Gbits/sec
[  5]   8.00-9.00   sec   913 MBytes  7.66 Gbits/sec
[  5]   9.00-10.00  sec   902 MBytes  7.57 Gbits/sec
[  5]   0.00-10.00  sec  8.63 GBytes  7.42 Gbits/sec                  sender
[  5]   0.00-10.00  sec  8.63 GBytes  7.42 Gbits/sec                  receiver
iperf Done.
From the servers side (Intel x540-T1) the iperf still only peaks at around 4 GBit/s:
iperf3 - FreeNAS to Windows
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec   457 MBytes  3.83 Gbits/sec    0    210 KBytes
[  5]   1.00-2.00   sec   461 MBytes  3.87 Gbits/sec    0    210 KBytes
[  5]   2.00-3.00   sec   448 MBytes  3.76 Gbits/sec    0    210 KBytes
[  5]   3.00-4.00   sec   436 MBytes  3.66 Gbits/sec    0    210 KBytes
[  5]   4.00-5.00   sec   457 MBytes  3.83 Gbits/sec    0    210 KBytes
[  5]   5.00-6.00   sec   425 MBytes  3.57 Gbits/sec    0    210 KBytes
[  5]   6.00-7.00   sec   474 MBytes  3.97 Gbits/sec    0    210 KBytes
[  5]   7.00-8.00   sec   467 MBytes  3.92 Gbits/sec    0    210 KBytes
[  5]   8.00-9.00   sec   482 MBytes  4.05 Gbits/sec    0    210 KBytes
[  5]   9.00-10.00  sec   481 MBytes  4.04 Gbits/sec    0    210 KBytes
[  5]   0.00-10.00  sec  4.48 GBytes  3.85 Gbits/sec    0             sender
[  5]   0.00-10.00  sec  4.48 GBytes  3.85 Gbits/sec                  receiver
iperf Done.
Are there any tunables besides jumbo frames that I can make to improve the network speed?
Relevant server stats:
- FreeNAS 11.2 U6
- Intel x540-T1 (valid) in PCIe x16 slot
- cat7 cabling (2 meters, peer 2 peer)
- Gigabyte GA X150-M PRO
- Xeon E1220v5
- 24 GB ECC RAM
Herr_Merlin
PCIe speed on the motherboard inside the server? So the 10G nic is connected way to slow?
Wanderhoden.
PCIe connection on motherboard: 3.0 x16
PCIe connector on network card: 2.0 x8
This shouldnt be the problem since I can receive with almost 8 GBit/s
I found some useful postings and did the tuning from the 10G network primer and also from 45Drives but most of the settings were set correctly already.
Warning: Some tunables killed my nginx service (Web UI). They even prevented to start it again (code 55: no buffer space available). I had to manually set back the values via command line to access the web interface again.
This was especially with the values sysctl net.inet.tcp.sendspace and sysctl net.inet.tcp.recvspace
