I'm running an issue with my server :
-supermicro x10sra-f + xeon e5 2680 v4
-boot on 2 ssd
-striped mirror disks as data
The server is booting fine without it, web interface ok.
When I insert the LSI 9208-16e card , the server is booting apparently normally, showing ip adress and boot menu, however apps and web UI never start up.I can see the bios post and the card showing up during boot.
If I remove the card, everything goes back normal.
I tried on a windows machine the card is ok. I tried on an old machine (z97 chipset , old i5) that I installed a fresh truenas scale, the web ui is showing normally, disks are recognized.
My conclusion is that something may be wrong with the os on the server...
Is there a way to repair Truenas OS without loosing all my apps & configuration?
Thanks a lot
-boot on 2 ssd
Thanks a lot
