11.3 Certificate 'freenas-pre-certui' has expired
PiP
I have upgraded my freenas setup to 11.3 U5 from 11.2 U8. I did this doing a clean install with new media and uploading the old 11.2 config.
I have an ongoing issue whereby the system is alerting: Certificate 'freenas-pre-certui' has expired. This post discusses and appears to be an open issue - should I be concerned by this, is there a fix?
Thanks in advance,
PiP
JaimieV
Mine is still sat there like a turkey from when I logged that bug (which was IMO erroneously closed):
It no longer alerts, thanks to the "fix" implemented, but I never even got any explanation of whether the system-generated cert 'freenas-pre-certui' is important. Or whether it was ever important.
I've seen similar queries go past here in the forum every month or two since, never seen any useful replies.
PiP
Thanks for the reply JamieV - what was the "fix" you implemented?
JaimieV
I didn't, I just left it there since I still don't know if it's needed.
The not-really-a-fix that Development implented was to not fire an alert on it any longer.
