How to renew freenas-pre-certui? Bad cert was generated, expired 9 years ago
JaimieV
An alert. "Certificate 'freenas-pre-certui' is expiring within -3101 days." Checking the cert, it ran from Wed Sep 7 01:02:33 2011 to Fri Oct 7 01:02:33 2011, which is not only long before I started using FreeNAS, but it's older than the server it's on. Some clock issue at install/upgrade time I guess, though that doesn't explain the one month duration. I only noticed it about two months ago, but since it's only a domestic machine I didn't care enough and just marked the alert as read. Now I have time on my hands...
Fine with having another self-signed, but I can't seem to find instructions on where&how to fix this up. I see it in System/Certificates. Can I just generate another one then delete old and add new? I presume the name is fixed; any other requirements? Being deleted would have major repercussions for the GUI, I will set it to HTTP only first. Does anything else use the cert that'll need refreshing/restarting manually?
JaimieV
Should I be concerned that there doesn't appear to be a way to do this?
Jenlain74
I have the same alert :
WARNING
Certificate 'freenas-pre-certui' is expiring within -2231 days.
Fri, 27 Mar 2020 08:48:49 AM (Europe/Paris)
And I'm asking myself the same questions...
JaimieV
Seems like the sort of thing the installer ought to look for and perhaps renew, given it is core functionality.
JaimieV
Anyone? I guess I should post a bug about it, if there isn't any way to do it currently.
Harrison
Seeing the same issue in Version: FreeNAS-11.3-U2:
WARNING
Certificate 'freenas-pre-certui' is expiring within -2059 days.
JaimieV
DeeEyeNL
I'm also getting this warning / alert in FreeNAS-11.3-U2
WARNING
Certificate 'freenas-pre-certui' is expiring within -2071 days.
JaimieV
Just to note that I just built a new box from scratch, and only got a freenas_default cert this time, with sensible dates (although it expires in 2022, and it'd be useful to have a "refresh cert" button by then!
I don't have that freenas_default cert on my machine Sisyphus, which was a new build around April last year. Only the described freenas-pre-certui exists on that system.
JaimieV
Ticket has been closed as a duplicate of the ticket I pointed out it wasn't a duplicate of. No resolution for these weird leftover certs, or documentation for how to do anything about them. Not very impressed.
giuseppe30
new installation TrueNas 12.0-U2 and for some reason certificate freenas_default are expired in 2011.
News for refresh it?
hilton8r
Sorry to post on an old thread, but I've had a critical alert for freenas-pre-certui with start date 20140324 / end date 20140423 for as long as I can remember. I just jumped up to TrueNas 12.0-U4.1, but it's still an issue. I thought about deleting the cert, but wanted to search for the umpteenth time for a solution before doing something I would regret. I don't see any way to generate a new cert. Has anyone found a solution for this yet? I haven't been able to find any direction so far. Thanks...
Patrick M. Hausen
There's a CA integrated right in the UI. What exactly is your problem with generating a new cert?
hilton8r
Patrick, I saw the option to delete the cert when clicking on the 3 dots to the right. I didn't see an option to create a new cert.
I've had this error for so long, and I always figured it would resolve itself. But honestly, I didn't understand much about certifications. All of my searches seemed to return threads showing people having the same problem as me, but no resolution. I do recall reading that the cert code was modified around 11.3 if I remember correctly.
After reading you response, I went back, and now I'm embarrassed that I didn't see the blue add button... Thank you for your reply. I appreciate it, and I think I'm good to go now. Take care.
Patrick M. Hausen
Keep in mind that you need to create a CA first. Then you can create and sign new certificates.
marcevan
I created a CA since a new Cert needs one.
Then I created a new Cert.
Tried to delete the existing FreeNAS-pre-CertUI and got [ebusy] as the cert is in use....
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 405, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/crypto.py", line 2063, in do_delete
self.middleware.call_sync('certificate.check_dependencies', id)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1272, in call_sync
return self.run_coroutine(methodobj(*prepared_call.args))
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1312, in run_coroutine
return fut.result()
File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 438, in result
return self.__get_result()
File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 390, in __get_result
raise self._exception
File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 612, in check_dependencies
raise CallError('This object is being used by other objects', errno.EBUSY,
middlewared.service_exception.CallError: [EBUSY] This object is being used by other objects
Patrick M. Hausen
I filled out everything for the new CA but "submit" is still greyed out. All (*) fields are filled so it's not lacking any required field.
Screenshot of all fields and content, please.
marcevan
