Rickinfl
- Aug 7, 2017
Running 11.2 Beta1 with VM's. Having issues with the NIC setup.
If you edit the NIC and change the Adapter type you can not save. The VM is Off. So I deleted the NIC and re-added the NIC setting the Adapter to VirtIO saved it. When back into the NIC settings and it's gone. So I dropped down the Menu and selected VirtIO again, but as before it will not allow me to save the button is blacked out.
