browntiger
- Oct 18, 2022
Can I suggest: (1) remove one card and create an alias and run k8s on one alias and truenas (ssl) on another. You do not need two cards.
If you do run two cards, you need to understand the issues involved. Since your servers are interconnected two both networks, having two cards each, the name to ip / to ARP to MAC resolution could be really bad. You could be getting randomly different IPs (internal or external). You will be getting this message that a server transitioned from internal ip to external ip and back. W/o fixes that setup is not stable.
You can set those configs and remediate the issues by manipulating hosts file and the arp table with e.g arp -s 192.168.86.65 00:50:ba:85:85:ca
If you want to go in that direction selecting something not routable:
192.168.86.10 (Public) and 192.169.86.10 (Private).
Or distinctly different subnets.
Do like 192.168.86.10/16 Public
And 10.7.10.10/16 Private
Be aware that Linux has this “Linux ARP flux” problem. When Linux answers ARP requests on wrong and unassociated interfaces per default. This is not for weak hearted.
