SOLVED 11.2-BETA - do obviously missing features call for a bug report?
Patrick M. Hausen
Hi all,
one example: in the "Cards" view of the VM section all you can do is "Connect" or Stop/Start depending on whether the VM is already running or not. In the "Table" view the menu choices are limited to "Edit", "Devices" and "Delete.
Would you consider this a bug you'd like a report in Redmine for or is this so obviously not yet implemented that I should rather just wait?
Kind regards
Patrick
Alecmascot
Yes. It is supposed to be feature complete.
Patrick M. Hausen
