Evan Richardson
 - Dec 11, 2015
my /usr/local/etc/snmpd.conf file looks like this:
All of these work (via the conf file, adding to auxillary area in gui does nothing), except the UPS-nut. if I run it manually (./ups-nut.sh) as root, it works:
but when I use snmp walk, it doesn't get any output:
contents of ups-nut:
AFAICT, snmp is running as root, so why does the .sh file work, but snmpd can't get any results from this one script? for reference, this came from librenms. Thanks!
Also, as a side question, shouldn't the GUI option take "extends"? I tried putting these lines in there, but could not find any file they got put in, and got zero metrics from the scripts. Only when I put them in /usr/local/etc/snmpd.conf did it finally work.
extend ntp-client /etc/snmp/ntp-client.sh extend fbsdnfsserver /etc/snmp/fbsdnfsserver extend smart /etc/snmp/smart extend nfs-server /usr/bin/nfsstat extend ups-nut /etc/snmp/ups-nut.sh
root@mediastore:/etc/snmp # ./ups-nut.sh 100 592 1320 53.8 48 120 122.0 56
root@mediastore:/etc/snmp # snmpwalk -v2c -c <community> x.x.x.x NET-SNMP-EXTEND-MIB::nsExtendObjects | grep ups-nut NET-SNMP-EXTEND-MIB::nsExtendCommand."ups-nut" = STRING: /etc/snmp/ups-nut.sh NET-SNMP-EXTEND-MIB::nsExtendArgs."ups-nut" = STRING: NET-SNMP-EXTEND-MIB::nsExtendInput."ups-nut" = STRING: NET-SNMP-EXTEND-MIB::nsExtendCacheTime."ups-nut" = INTEGER: 5 NET-SNMP-EXTEND-MIB::nsExtendExecType."ups-nut" = INTEGER: exec(1) NET-SNMP-EXTEND-MIB::nsExtendRunType."ups-nut" = INTEGER: run-on-read(1) NET-SNMP-EXTEND-MIB::nsExtendStorage."ups-nut" = INTEGER: permanent(4) NET-SNMP-EXTEND-MIB::nsExtendStatus."ups-nut" = INTEGER: active(1) NET-SNMP-EXTEND-MIB::nsExtendOutput1Line."ups-nut" = STRING: Unknown NET-SNMP-EXTEND-MIB::nsExtendOutputFull."ups-nut" = STRING: Unknown NET-SNMP-EXTEND-MIB::nsExtendOutNumLines."ups-nut" = INTEGER: 8 NET-SNMP-EXTEND-MIB::nsExtendResult."ups-nut" = INTEGER: 0 NET-SNMP-EXTEND-MIB::nsExtendOutLine."ups-nut".1 = STRING: Unknown NET-SNMP-EXTEND-MIB::nsExtendOutLine."ups-nut".2 = STRING: Unknown NET-SNMP-EXTEND-MIB::nsExtendOutLine."ups-nut".3 = STRING: Unknown NET-SNMP-EXTEND-MIB::nsExtendOutLine."ups-nut".4 = STRING: Unknown NET-SNMP-EXTEND-MIB::nsExtendOutLine."ups-nut".5 = STRING: Unknown NET-SNMP-EXTEND-MIB::nsExtendOutLine."ups-nut".6 = STRING: Unknown NET-SNMP-EXTEND-MIB::nsExtendOutLine."ups-nut".7 = STRING: Unknown NET-SNMP-EXTEND-MIB::nsExtendOutLine."ups-nut".8 = STRING: Unknown
UPS_NAME='ups'
PATH=$PATH:/usr/bin:/bin
TMP=$(upsc $UPS_NAME 2>/dev/null)
for value in "battery\.charge: [0-9.]+" "battery\.(runtime\.)?low: [0-9]+" "battery\.runtime: [0-9]+" "battery\.voltage: [0-9.]+" "battery\.voltage\.nominal: [0-9]+" "input\.voltage\.nominal: [0-9.]+" "input\.voltage: [0-9.]+" "ups\.load: [0-9.]+"
do
		OUT=$(echo $TMP | grep -Eo "$value" | awk '{print $2}' | LANG=C sort | head -n 1)
		if [ -n "$OUT" ]; then
				echo $OUT
		else
				echo "Unknown"
		fi
done
