extending SNMP (getting crazy)
crester
Newbie
Hello.
FreeNAS-9.10-STABLE-201604111739 (896cc83)
I am trying to extend SNMP to process some bash scripts.
Begining from scratch I am trying a very simple script:
in Services -> SNMP ->Auxiliary parameters
extend test/bin/echo hello
ssh to server and:
[root@freenas] ~/bin# snmpwalk -v2c -c public localhost nsExtendOutput1
NET-SNMP-EXTEND-MIB::nsExtendOutput1Line."test" = STRING: hello
NET-SNMP-EXTEND-MIB::nsExtendOutputFull."test" = STRING: hello
NET-SNMP-EXTEND-MIB::nsExtendOutNumLines."test" = INTEGER: 1
NET-SNMP-EXTEND-MIB::nsExtendResult."test" = INTEGER: 0
looks fine
[root@freenas] ~/bin# snmptranslate -On NET-SNMP-EXTEND-MIB::nsExtendOutput1Line.\"test\"
.1.3.6.1.4.1.8072.1.3.2.3.1.1.4.116.101.115.116
looks fine,
but
[root@freenas] ~/bin# snmpget -v2c -c public localhost test
IF-MIB::ifTestGroup = No Such Object available on this agent at this OID
[root@freenas] ~/bin# snmpget -v2c -c public localhost NET-SNMP-EXTEND-MIB::test
NET-SNMP-EXTEND-MIB::test: Unknown Object Identifier
I am almost sure it is a simple solution, but I have been working for 4 hours against this and I am unable to locate the problem.
Some help will be appreciated, thanks
jgreco
Resident Grinch
mod note: Evicted from installation forum, nothing to do with installation.
I'll note that it is sometimes clearer what is going on if you instead just use the numeric OID's when doing your initial "does it work" testing, rather than heaping the translation layer on as well.
