EDIT: Here is the Zabbix template I created. https://share.zabbix.com/storage-devices/freenas-11
Firstly here are my system specifications.
Version: FreeNAS-11.1-U2
CPUI: Intel(R) Xeon(R) CPU E3-1220L V2 @ 2.30GHz
RAM: 16311MB (ECC)
HP Microserver Gen8
2 x 4TB Western Digital NAS Red Drives
So I am trying to setup SNMP monitoring via Zabbix, I did discover a template here: https://share.zabbix.com/storage-devices/freenas-snmp-w-zfs-stats however this will need updating to work with FreeNAS 11.1 which I am happy to do.
I downloaded the MIB FreeNAS-MIB.txt from /usr/local/share/snmp/mibs/FREENAS-MIB.txt to my linux desktop with snmpwalk on it.
I can see in the MIB file the zpool entries:
Running:
I get:
So I should be able to append either .0 or .1 to get the zpool I want? Unfortunately I get index out of range which doesn't seem correct to me.
I think there might be a bug in the MIB? I changed the integer32 be 0..2147483647 and it worked.
zpoolIndex OBJECT-TYPE
SYNTAX Integer32 (1..2147483647)
MAX-ACCESS not-accessible
STATUS current
DESCRIPTION
::= { zpoolEntry 1 }
I seemed to fix it while writing this forum post. I will raise a bug and post the bug number here.
RAM: 16311MB (ECC)
HP Microserver Gen8
ZpoolEntry ::= SEQUENCE { zpoolIndex Integer32, zpoolDescr DisplayString, zpoolAllocationUnits Integer32, zpoolSize Integer32, zpoolUsed Integer32, zpoolAvailable Integer32, zpoolHealth ZPoolHealthType, zpoolReadOps Counter64, zpoolWriteOps Counter64, zpoolReadBytes Counter64, zpoolWriteBytes Counter64, zpoolReadOps1sec Counter64, zpoolWriteOps1sec Counter64, zpoolReadBytes1sec Counter64, zpoolWriteBytes1sec Counter64 }
Running:
snmpwalk -v 2c -c MyCommunity 172.16.80.80 FREENAS-MIB::zpoolDescr
I get:
FREENAS-MIB::zpoolDescr.0 = STRING: OneDrive FREENAS-MIB::zpoolDescr.1 = STRING: freenas-boot
[root@centos ~]# snmpwalk -v 2c -c MyCommunity 172.16.80.80 FREENAS-MIB::zpoolDescr.0
FREENAS-MIB::zpoolDescr.0: Unknown Object Identifier (Index out of range: 0 (zpoolIndex))
[root@centos ~]# snmpwalk -v 2c -c MyCommunity 172.16.80.80 FREENAS-MIB::zpoolDescr.1
STATUS current
DESCRIPTION
