SubnetMask
- Jul 27, 2017
I've tried twice now to update my FreeNAS 11.1 to 11.1 U1, and both times it's failed. In the Web UI, it hangs at 'Installing base-os (1/5)', and on the console, I get a bunch of 'CAM status: CCB request completed with an error' messages (and it's mostly unresponsive). I did some searching around and it seems like there is some kind of 'issue' with 16GB Sandisk Cruzer Fit USB drives and FreeNAS, as those seem to be mentioned a lot related to this issue (and that happens to be what I'm using) on a pretty diverse range of hardware, and it seems to go back as far as FreeNAS 9. It also seems that pretty much everyone that has seen these issues and has tested the drives has found them to be error free. I then tried to upgrade it from a bootable USB by creating a new boot environment (essentially the same as upgrading from the UI), rather than formatting it and I got the same issue. I then tried again, but this time, I told it 'Upgrade', then 'Format Boot Volume'. This time, it went perfectly. Everything copied fine, it migrated the settings, and upon first boot, it created the 'Initial Install' boot environment and all seems well.
If anyone has any other thoughts or info that I missed, I'd like to hear it, otherwise, hopefully this might be another bit of useful info for someone.
