Hi folks,
I have a 6 disk + single SSD cache RAIDZ1 setup running on 9.3 latest.
Main disks at 6 x 4TB Reds and a OCZ 60GB SSD for the cache.
I was moving a large amount of data around and decided to look at iostat for laughs. It shows something odd for the SSD though:
Why would it be reporting 589G on a 60GB disk? As the copy continues it does up and up. It's currently at 603GB
Signs that the disk is not happy? A SMART report says all is well. (or does it?)
Thanks
Crispin
capacity operations bandwidth pool alloc free read write read write -------------------------------------- ----- ----- ----- ----- ----- ----- tank 9.35T 12.4T 523 953 63.9M 106M raidz1 9.35T 12.4T 523 953 63.9M 106M gptid/349c35f9-445d-11e5-8abf-2c27d7158144 - - 148 240 12.5M 22.1M gptid/3519e6c4-445d-11e5-8abf-2c27d7158144 - - 135 292 12.3M 27.6M gptid/eebe1ba0-4a9f-11e5-93f3-2c27d7158144 - - 139 291 12.6M 27.5M gptid/367dc071-445d-11e5-8abf-2c27d7158144 - - 132 251 12.4M 23.9M gptid/376dde13-445d-11e5-8abf-2c27d7158144 - - 139 269 12.6M 25.3M gptid/e25a04e4-4b4d-11e5-a068-2c27d7158144 - - 133 285 12.4M 27.8M cache - - - - - - gptid/38b64f4a-445d-11e5-8abf-2c27d7158144 589G 16.0E 1 339 7.97K 41.8M
########## SMART status report for ada1 drive (SandForce Driven SSDs: OCZ-B592KW38CR0R1K0D) ########## SMART overall-health self-assessment test result: PASSED ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 092 092 050 Pre-fail Always - 102/178934374 5 Retired_Block_Count 0x0033 100 100 003 Pre-fail Always - 0 9 Power_On_Hours_and_Msec 0x0032 099 099 000 Old_age Always - 960h+57m+01.888s 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 358 171 Program_Fail_Count 0x0032 000 000 000 Old_age Always - 0 172 Erase_Fail_Count 0x0032 000 000 000 Old_age Always - 0 174 Unexpect_Power_Loss_Ct 0x0030 000 000 000 Old_age Offline - 214 177 Wear_Range_Delta 0x0000 000 000 000 Old_age Offline - 2 181 Program_Fail_Count 0x0032 000 000 000 Old_age Always - 0 182 Erase_Fail_Count 0x0032 000 000 000 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 194 Temperature_Celsius 0x0022 128 129 000 Old_age Always - 128 (0 127 0 129 0) 195 ECC_Uncorr_Error_Count 0x001c 120 120 000 Old_age Offline - 102/178934374 196 Reallocated_Event_Count 0x0033 100 100 003 Pre-fail Always - 0 201 Unc_Soft_Read_Err_Rate 0x001c 120 120 000 Old_age Offline - 102/178934374 204 Soft_ECC_Correct_Rate 0x001c 120 120 000 Old_age Offline - 102/178934374 230 Life_Curve_Status 0x0013 100 100 000 Pre-fail Always - 83992380440676 231 SSD_Life_Left 0x0013 094 094 010 Pre-fail Always - 0 233 SandForce_Internal 0x0000 000 000 000 Old_age Offline - 17350 234 SandForce_Internal 0x0032 000 000 000 Old_age Always - 16303 241 Lifetime_Writes_GiB 0x0032 000 000 000 Old_age Always - 16303 242 Lifetime_Reads_GiB 0x0032 000 000 000 Old_age Always - 4643 SMART Error Log not supported
Thanks
Crispin
