SOLVED Pool degraded; mirror-1 too many errors
TerryVog
My pool is degraded because of mirror-1. What should I do?
Here is the result of zpool status -v:
root@freenas:~ # zpool status -v
  pool: TM
 state: DEGRADED
status: One or more devices has experienced an unrecoverable error.  An
        attempt was made to correct the error.  Applications are unaffected.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
  scan: scrub repaired 0B in 04:50:58 with 0 errors on Wed Nov 17 16:55:35 2021
        TM                                              DEGRADED     0     0 0
          mirror-0                                      ONLINE       0     0 0
            gptid/66c6f9a2-cc0f-11e5-b9f3-60a44caefdbd  ONLINE       0     0 0
            gptid/f48b4bd1-3c00-11e5-b5da-60a44caefdbd  ONLINE       0     0 0
          mirror-1                                      DEGRADED     0     0 0
            gptid/b50d8539-9c33-11e5-82d9-60a44caefdbd  DEGRADED     0     0 0  too many errors
            gptid/b5bbf4c4-9c33-11e5-82d9-60a44caefdbd  DEGRADED     0     0 0  too many errors
          mirror-2                                      ONLINE       0     0 0
            gptid/002b97d6-ada4-11eb-9eb3-60a44caefdbd  ONLINE       0     0 0
            gptid/7afe6a65-6e0a-11eb-8c0c-60a44caefdbd  ONLINE       0     0 0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
        still be used, but some features are unavailable.
        the features. See zpool-features(5) for details.
  scan: scrub repaired 0B in 00:08:29 with 0 errors on Fri Nov 19 03:53:29 2021
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
          da0p2       ONLINE       0     0     0
I also ran smartctl -A on each of my 6 disks:
root@freenas:~ # smartctl -A /dev/ada0
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p10 amd64] (local build)
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   184   179   021    Pre-fail  Always       -       5783
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       162
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   035   035   000    Old_age   Always       -       47679
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       162
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       134
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1544
194 Temperature_Celsius     0x0022   115   105   000    Old_age   Always       -       35
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
root@freenas:~ # smartctl -A /dev/ada1
  1 Raw_Read_Error_Rate     0x000f   119   099   006    Pre-fail  Always       -       229842384
  3 Spin_Up_Time            0x0003   094   093   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       186
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   088   060   030    Pre-fail  Always       -       788306663
  9 Power_On_Hours          0x0032   045   045   000    Old_age   Always       -       49020
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       187
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       17180131332
189 High_Fly_Writes         0x003a   001   001   000    Old_age   Always       -       900
190 Airflow_Temperature_Cel 0x0022   063   053   045    Old_age   Always       -       37 (Min/Max 18/40)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       156
193 Load_Cycle_Count        0x0032   099   099   000    Old_age   Always       -       2168
194 Temperature_Celsius     0x0022   037   047   000    Old_age   Always       -       37 (0 17 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
root@freenas:~ # smartctl -A /dev/ada2
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       2
  3 Spin_Up_Time            0x0027   184   179   021    Pre-fail  Always       -       5791
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       212
  9 Power_On_Hours          0x0032   029   029   000    Old_age   Always       -       52059
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       211
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       182
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1612
194 Temperature_Celsius     0x0022   114   104   000    Old_age   Always       -       36
root@freenas:~ # smartctl -A /dev/ada3
  1 Raw_Read_Error_Rate     0x000f   116   099   006    Pre-fail  Always       -       113587976
  7 Seek_Error_Rate         0x000f   088   060   030    Pre-fail  Always       -       775739856
  9 Power_On_Hours          0x0032   045   045   000    Old_age   Always       -       49001
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       186
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       12885098499
189 High_Fly_Writes         0x003a   001   001   000    Old_age   Always       -       762
190 Airflow_Temperature_Cel 0x0022   061   052   045    Old_age   Always       -       39 (Min/Max 18/41)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       157
193 Load_Cycle_Count        0x0032   099   099   000    Old_age   Always       -       2169
194 Temperature_Celsius     0x0022   039   048   000    Old_age   Always       -       39 (0 16 0 0 0)
root@freenas:~ # smartctl -A /dev/ada4
  3 Spin_Up_Time            0x0027   205   205   021    Pre-fail  Always       -       2733
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       6
  9 Power_On_Hours          0x0032   094   094   000    Old_age   Always       -       4677
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       5
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       3
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       2
194 Temperature_Celsius     0x0022   104   096   000    Old_age   Always       -       43
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
root@freenas:~ # smartctl -A /dev/ada5
  3 Spin_Up_Time            0x0027   202   198   021    Pre-fail  Always       -       2866
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       27
  9 Power_On_Hours          0x0032   092   092   000    Old_age   Always       -       6427
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       26
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       16
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       10
194 Temperature_Celsius     0x0022   105   098   000    Old_age   Always       -       42
And now I'm stuck. What is the next step?
Those disks look OK according to the SMART output... but watch ada2... just a couple of read errors.
Start by having a think about what could be problematic in terms of other hardware... I don't have a view on what you have to suggest anything.
You could simply try a zpool clear TM to see if the errors were something transient or if they come back.
Now may also be an excellent time to make sure you have a backup of any data from that pool that you would be sad to lose.
Just be wary of that setup for the moment... you may see errors coming back on the next scrub or long SMART tests.
Backups are vital if you have important data on it.
