jeepmkcomin
- Jul 18, 2015
Background: I had SMART warnings coming out of a disk and I decided to try and replace before it went. I ordered a disk and unfortunately the other one failed before I could replace. Therefore it was no longer showing. I ran a zpool replace after putting a new drive in and let it resliver. Once it finished I still had the alert in the GUI so I restarted to see if that would clear it and unfortunately my pool "Volume1" disappeared from being recognized by "zpool status" but was showing up in the GUI. I noticed it was showing when I'd type "zpool import". It wouldn't let me auto-import via the GUI due to it already existing from the GUI's point of view.
I'm not going to pretend to be well voiced in ZFS. I did a lot of searching on here and ultimately don't feel as if I'm going to get my data back at this point. Note that in the zpool import "ada0" is the new drive. I'm not sure how I failed to have it add properly and receive a naming scheme similar to the others. If anyone has any advice I'm happy to give it a go.
I reset the gui piece to factory specs to get a clean slate there so I could enable the ssh service to copy out of puTTy the following command returns.
FreeNAS-8.3.0-RELEASE-x64 (r12701M)
zpool status
zpool import
gpart show
gpart list
camcontrol devlist
glabel list
zpool status
[root@freenas] ~# zpool status no pools available
zpool import
[root@freenas] ~# zpool import
pool: Volume1
state: UNAVAIL
status: The pool is formatted using an incompatible version.
action: The pool cannot be imported. Access the pool on a system running newer
software, or recreate the pool from backup.
see: http://www.sun.com/msg/ZFS-8000-A5
Volume1 UNAVAIL newer version
raidz2-0 ONLINE
ada0 ONLINE
gptid/70cb3bd5-1ff3-11e2-97a4-14dae96864bc ONLINE
gptid/79c2fb42-6bb4-11e4-82ca-14dae96864bc ONLINE
gptid/719aa39f-1ff3-11e2-97a4-14dae96864bc ONLINE
gpart show
[root@freenas] ~# gpart show
=> 34 1953525101 ada1 GPT (931G)
34 94 - free - (47k)
128 4194304 1 freebsd-swap (2.0G)
4194432 1949330703 2 freebsd-zfs (929G)
=> 34 7814037101 ada2 GPT (3.7T)
4194432 7809842696 2 freebsd-zfs (3.7T)
7814037128 7 - free - (3.5k)
=> 34 1953525101 ada3 GPT (931G)
=> 63 15727761 ada4 MBR (7.5G)
63 1930257 1 freebsd [active] (942M)
1930320 63 - free - (31k)
1930383 1930257 2 freebsd (942M)
3860640 3024 3 freebsd (1.5M)
3863664 41328 4 freebsd (20M)
3904992 11822832 - free - (5.7G)
=> 0 1930257 ada4s1 BSD (942M)
0 16 - free - (8.0k)
16 1930241 1 !0 (942M)
=> 0 1930257 ada4s2 BSD (942M)
gpart list
[root@freenas] ~# gpart list Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1953525134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 rawuuid: 70bd14b0-1ff3-11e2-97a4-14dae96864bc rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 rawuuid: 70cb3bd5-1ff3-11e2-97a4-14dae96864bc rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 998057319936 offset: 2147549184 type: freebsd-zfs index: 2 end: 1953525134 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 1000204886016 (931G) Sectorsize: 512 Mode: r0w0e0 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 7814037134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 793a956d-6bb4-11e4-82ca-14dae96864bc rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada2p2 Mediasize: 3998639460352 (3.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 79c2fb42-6bb4-11e4-82ca-14dae96864bc rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 3998639460352 offset: 2147549184 type: freebsd-zfs index: 2 end: 7814037127 start: 4194432 Consumers: 1. Name: ada2 Mediasize: 4000787030016 (3.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada3 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1953525134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 rawuuid: 718cd077-1ff3-11e2-97a4-14dae96864bc rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada3p2 Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 rawuuid: 719aa39f-1ff3-11e2-97a4-14dae96864bc rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 998057319936 offset: 2147549184 type: freebsd-zfs index: 2 end: 1953525134 start: 4194432 Consumers: 1. Name: ada3 Mediasize: 1000204886016 (931G) Sectorsize: 512 Mode: r0w0e0 Geom name: ada4 modified: false state: OK fwheads: 16 fwsectors: 63 last: 15727823 first: 63 entries: 4 scheme: MBR Providers: 1. Name: ada4s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e2 attrib: active rawtype: 165 length: 988291584 offset: 32256 type: freebsd index: 1 end: 1930319 start: 63 2. Name: ada4s2 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988356096 Mode: r0w0e0 rawtype: 165 length: 988291584 offset: 988356096 type: freebsd index: 2 end: 3860639 start: 1930383 3. Name: ada4s3 Mediasize: 1548288 (1.5M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1976647680 Mode: r0w0e0 rawtype: 165 length: 1548288 offset: 1976647680 type: freebsd index: 3 end: 3863663 start: 3860640 4. Name: ada4s4 Mediasize: 21159936 (20M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1978195968 Mode: r1w1e2 rawtype: 165 length: 21159936 offset: 1978195968 type: freebsd index: 4 end: 3904991 start: 3863664 Consumers: 1. Name: ada4 Mediasize: 8052645888 (7.5G) Sectorsize: 512 Mode: r2w1e5 Geom name: ada4s1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1930256 first: 0 entries: 8 scheme: BSD Providers: 1. Name: ada4s1a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 40448 Mode: r1w0e2 rawtype: 0 length: 988283392 offset: 8192 type: !0 index: 1 end: 1930256 start: 16 Consumers: 1. Name: ada4s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e2 Geom name: ada4s2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1930256 first: 0 entries: 8 scheme: BSD Providers: 1. Name: ada4s2a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988364288 Mode: r0w0e0 rawtype: 0 length: 988283392 offset: 8192 type: !0 index: 1 end: 1930256 start: 16 Consumers: 1. Name: ada4s2 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988356096 Mode: r0w0e0
camcontrol devlist
[root@freenas] ~# camcontrol devlist <ST4000VN000-1H4168 SC46> at scbus0 target 0 lun 0 (pass0,ada0) <ST31000340AS SD1A> at scbus1 target 0 lun 0 (pass1,ada1) <ST4000VN000-1H4168 SC46> at scbus2 target 0 lun 0 (pass2,ada2) <ST31000340AS SD1A> at scbus3 target 0 lun 0 (pass3,ada3) <Emphase SFM20I-8G rs1.a000> at scbus5 target 0 lun 0 (pass4,ada4)
glabel list
[root@freenas] ~# glabel list Geom name: ada1p1 Providers: 1. Name: gptid/70bd14b0-1ff3-11e2-97a4-14dae96864bc Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 4194304 length: 2147483648 index: 0 Consumers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 Geom name: ada1p2 Providers: 1. Name: gptid/70cb3bd5-1ff3-11e2-97a4-14dae96864bc Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 1949330703 length: 998057319936 index: 0 Consumers: 1. Name: ada1p2 Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 Geom name: ada2p1 Providers: 1. Name: gptid/793a956d-6bb4-11e4-82ca-14dae96864bc Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 4194304 length: 2147483648 index: 0 Consumers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada2p2 Providers: 1. Name: gptid/79c2fb42-6bb4-11e4-82ca-14dae96864bc Mediasize: 3998639460352 (3.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 7809842696 length: 3998639460352 index: 0 Consumers: 1. Name: ada2p2 Mediasize: 3998639460352 (3.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada3p1 Providers: 1. Name: gptid/718cd077-1ff3-11e2-97a4-14dae96864bc Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 4194304 length: 2147483648 index: 0 Consumers: 1. Name: ada3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 Geom name: ada3p2 Providers: 1. Name: gptid/719aa39f-1ff3-11e2-97a4-14dae96864bc Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 1949330703 length: 998057319936 index: 0 Consumers: 1. Name: ada3p2 Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 Geom name: ada4s3 Providers: 1. Name: ufs/FreeNASs3 Mediasize: 1548288 (1.5M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1976647680 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 3024 length: 1548288 index: 0 Consumers: 1. Name: ada4s3 Mediasize: 1548288 (1.5M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1976647680 Mode: r0w0e0 Geom name: ada4s4 Providers: 1. Name: ufs/FreeNASs4 Mediasize: 21159936 (20M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1978195968 Mode: r1w1e1 secoffset: 0 offset: 0 seclength: 41328 length: 21159936 index: 0 Consumers: 1. Name: ada4s4 Mediasize: 21159936 (20M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1978195968 Mode: r1w1e2 Geom name: ada4s1a Providers: 1. Name: ufs/FreeNASs1a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 40448 Mode: r1w0e1 secoffset: 0 offset: 0 seclength: 1930241 length: 988283392 index: 0 Consumers: 1. Name: ada4s1a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 40448 Mode: r1w0e2 Geom name: ada4s2a Providers: 1. Name: ufsid/521c684590455604 Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988364288 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 1930241 length: 988283392 index: 0 Consumers: 1. Name: ada4s2a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988364288 Mode: r0w0e0 Geom name: ada4s2a Providers: 1. Name: ufs/FreeNASs2a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988364288 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 1930241 length: 988283392 index: 0 Consumers: 1. Name: ada4s2a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988364288 Mode: r0w0e0
