mbonato
 - Aug 22, 2019
Hi! This is my first post to the forum, so I apologise in advance if I miss out on any of the rules. However, I will try me best ;-)
We have a FreeNAS mini box (2016) that worked quite fine until a few days. One of the drives started to show errors in SMART and we decided to replace the drive with a new one. I followed the instructions from the official documentation (https://www.ixsystems.com/documentation/freenas/11.2/storage.html#replacing-a-failed-disk) to replace the failing disk. After I've replaced the disk in the zpool resilvering started as expected. However, after a few hours resilvering stopped and
I spend some hours searching online and reading documentation, however I still don't understand if this is actually a hardware issue or "only" the pool (data) being corrupt beyond repair.
I'm still able to access most of the data and there are replication tasks for all relevant datasets. Also periodic SMART tests are in place and SMART does not report any issues with the other disks.
In the posts referring to similar issues I've found so far, it has been suggested that this might be caused by general hardware issues like inappropriate hardware, failing RAM etc. Since we use a FreeNAS mini box, I assume appropriate hardware ;-). Also RAM should be ECC according to the specs. Therefore, I would expect to notice if RAM is failing!? (System has not crashed and BMC event log does not show any errors.)
I've tried to reboot the FreeNas and resilvering started again automatically. However, with the same results - showing "too many errors" after a while.
So my questions are:
Thank you very much in advance,
Martin
zpool status showed thousands of CKSUM errors and it stated "too many errors" for all the other drives in the pool:Code:
  pool: nas
 state: DEGRADED
    corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
    entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: resilvered 2.41T in 0 days 19:46:37 with 3064 errors on Wed Aug 21 08:49:14 2019
    NAME                                              STATE     READ WRITE CKSUM
    nas                                               DEGRADED     0     0 10.6K
      raidz1-0                                        DEGRADED     0     0 37.0K
        gptid/095eaba3-3c9b-11e6-a8b9-d05099c0ff1f    DEGRADED     0     0     0  too many errors
        replacing-1                                   OFFLINE      0     0     0
          130027861328944270                          OFFLINE      0     0     0  was /dev/gptid/0a27642e-3c9b-11e6-a8b9-d05099c0ff1f
          gptid/02fc3662-c33a-11e9-abfd-d05099c38b3b  ONLINE       0     0     0
        gptid/0b0c6d57-3c9b-11e6-a8b9-d05099c0ff1f    DEGRADED     0     0   212  too many errors
        gptid/0be771f2-3c9b-11e6-a8b9-d05099c0ff1f    DEGRADED     0     0     0  too many errorsI spend some hours searching online and reading documentation, however I still don't understand if this is actually a hardware issue or "only" the pool (data) being corrupt beyond repair.
- What could be the reason for the CKSUM errors? Are all the other drives failing as well - although they don't show any READ or WRITE errors and SMART does not indicate any drive issues?
 - What is the best way to proceed? Can I recover from the errors (i accept loosing some data) without the need to rebuild the entire pool configuration? Do I need to replace the other harddisks as well?
Martin
# smartctl -a /dev/ada1
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red
Device Model:     WDC WD40EFRX-68WT0N0
Serial Number:    WD-WCC4E5SHSYVV
LU WWN Device Id: 5 0014ee 261ffe05b
Firmware Version: 82.00A82
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Thu Aug 22 13:48:18 2019 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (51540) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 515) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x703d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   181   179   021    Pre-fail  Always       -       7941
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       43
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   062   062   000    Old_age   Always       -       28224
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       43
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       20
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1171
194 Temperature_Celsius     0x0022   120   108   000    Old_age   Always       -       32
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     28137         -
# 2  Short offline       Completed without error       00%     28136         -
# 3  Short offline       Completed without error       00%     28135         -
# 4  Short offline       Completed without error       00%     28134         -
# 5  Short offline       Completed without error       00%     28133         -
# 6  Short offline       Completed without error       00%     28132         -
# 7  Short offline       Completed without error       00%     28131         -
# 8  Short offline       Completed without error       00%     28130         -
# 9  Short offline       Completed without error       00%     28129         -
#10  Short offline       Completed without error       00%     28128         -
#11  Short offline       Completed without error       00%     28127         -
#12  Short offline       Completed without error       00%     28126         -
#13  Short offline       Completed without error       00%     28125         -
#14  Short offline       Completed without error       00%     28124         -
#15  Short offline       Completed without error       00%     28123         -
#16  Short offline       Completed without error       00%     28123         -
#17  Short offline       Completed without error       00%     28121         -
#18  Short offline       Completed without error       00%     28121         -
#19  Short offline       Completed without error       00%     28120         -
#20  Short offline       Completed without error       00%     28119         -
#21  Short offline       Completed without error       00%     28118         -
# smartctl -a /dev/ada2
Device Model:     WDC WD40EFRX-68N32N0
Serial Number:    WD-WCC7K2JUCUKY
LU WWN Device Id: 5 0014ee 21167d6f2
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Thu Aug 22 13:49:01 2019 CEST
                    was never started.
                    been run.
data collection:         (43440) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 462) minutes.
SCT capabilities:            (0x303d)    SCT Status supported.
  3 Spin_Up_Time            0x0027   100   253   021    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       1
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       48
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       1
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   119   116   000    Old_age   Always       -       31
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
If Selective self-test is pending on power-up, resume after 0 minute delay.Code:
# smartctl -a /dev/ada3
Serial Number:    WD-WCC4E7RP1H6Y
LU WWN Device Id: 5 0014ee 2b7559aa7
Local Time is:    Thu Aug 22 13:51:57 2019 CEST
                    was never started.
                    been run.
data collection:         (54240) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 542) minutes.
  3 Spin_Up_Time            0x0027   253   177   021    Pre-fail  Always       -       4200
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       47
  9 Power_On_Hours          0x0032   062   062   000    Old_age   Always       -       28221
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       47
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       24
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1161
194 Temperature_Celsius     0x0022   119   108   000    Old_age   Always       -       33
No Errors Logged
# 1  Short offline       Completed without error       00%     28117         -
# 2  Short offline       Completed without error       00%     28116         -
# 3  Short offline       Completed without error       00%     28115         -
# 4  Short offline       Completed without error       00%     28113         -
# 5  Short offline       Completed without error       00%     28112         -
# 6  Short offline       Completed without error       00%     27967         -
# 7  Short offline       Completed without error       00%     27966         -
# 8  Short offline       Completed without error       00%     27965         -
# 9  Short offline       Completed without error       00%     27964         -
#10  Short offline       Completed without error       00%     27963         -
#11  Short offline       Completed without error       00%     27962         -
#12  Short offline       Completed without error       00%     27961         -
#13  Short offline       Completed without error       00%     27960         -
#14  Short offline       Completed without error       00%     27959         -
#15  Short offline       Completed without error       00%     27958         -
#16  Short offline       Completed without error       00%     27957         -
#17  Short offline       Completed without error       00%     27956         -
#18  Short offline       Completed without error       00%     27955         -
#19  Short offline       Completed without error       00%     27954         -
#20  Short offline       Completed without error       00%     27953         -
#21  Short offline       Completed without error       00%     27952         -
# smartctl -a /dev/ada4
Serial Number:    WD-WCC4E2FFACLN
LU WWN Device Id: 5 0014ee 20ca86e2a
Local Time is:    Thu Aug 22 13:53:13 2019 CEST
                    was never started.
                    been run.
                    command.
                    power-saving mode.
  3 Spin_Up_Time            0x0027   185   183   021    Pre-fail  Always       -       7708
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       44
  9 Power_On_Hours          0x0032   062   062   000    Old_age   Always       -       28223
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       44
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       21
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       1215
No Errors Logged
#16  Short offline       Completed without error       00%     28122         -
#18  Short offline       Completed without error       00%     28120         -
#19  Short offline       Completed without error       00%     28119         -
#20  Short offline       Completed without error       00%     28118         -
#21  Short offline       Completed without error       00%     28117         -
