ZFS SLOG not speeding up writes, and recommended size for 10 GBit LAN
flashdrive
Having added a 128 GByte SLOG device (Samsung 830 SSD) in TrueNAS CORE and SCALE I do not see any write speed improvements during 10 GB LAN write operations.
  • How can I make sure the the SSD is being utilised? The IO stat for sure.
  • Is there any tuning to be done?
In my understanding the SLOG device needs to be faster / more responsive then the HDD pool to see a benefit.
SLOG Devices
Disk latency is the primary concern for SLOG devices. The SLOG device only needs to store as much data as the system can throughput over the approximately 5 second “flush” period. With a 1GB connection, this is about 0.625 GiB. A 10GB connection requires about 6.25 GiB and 4x10 GiB requires 25 GiB.
c77dk
gstat, zilstat and zpool iostat are what I would look at
Do you have sync writes? If you don't, an SLOG is going to gather dust and do little more.
Not at all a good choice of SLOG. Since it does not have power loss protection, it is no safer than eschewing sync writes entirely. You'd get the worst of both worlds: no ZIL and worse performance.
Its performance characteristics are also going to be unimpressive for SLOG applications, but that's the least of your concerns.
flashdrive
thank you for your feedback.
I have found this thread:
My goal for my homelab host / server is the same: SMB writes / ingest mostly.
So what would be the way to go to have a good write performance?
For now I am around 400 Mbyte / s with 5 HDDs and 10 GB LAN.
I know that by writing to a RAM disk I can get near to the theoratical max of 10 GB LAN copper based.
rvassar
SMB isn't going to make use of a SLOG much, if at all.
To maximize performance here, you're probably going to want some kind of multi-vdev pool configuration. A single vdev RAIDz2 pool will have limited write performance. Consider mirrors, or a multi-vdev RAID config where the kernel can round-robin to the other group of disks and perform writes in parallel. But even then, you have to consider the spindle performance of each drive. I have a 4 device mirror pool, and I still can't hit full 10GbE speeds. Since each drive tops out at 150 mb/sec or so, I'm guessing I need 6 or 8 drives in 3 or 4 mirror vdevs.
This is why all those little sub-2Tb 2.5" 10k & 15k rpm drives lingered in the Enterprise for so long. They didn't hold much, but prior to reasonable flash/NVMe, they put up serious IOPS numbers in large groups.
Windows does not request many sync writes over SMB. Mac OS seems to do a fair bit more sync writes, though.
flashdrive
Ok, however I want Windows OS to send the data to the NAS.
flashdrive
