ZFS Replication iocage dataset spams console
warriorcookie
Member
I have 4 replication tasks setup to replicate some datasets from one freenas server to another
3 of the tasks complete without issue, but the 4th is for my iocage dataset and it spams my console with a number of errors:
Jun 8 23:00:29 backupnas collectd[1574]: statfs(/mnt/backupnas/Data1/iocage/jails) failed: No such file or directory
Jun 8 23:00:49 backupnas collectd[1574]: statfs(/mnt/backupnas/Data1/iocage/log) failed: No such file or directory
Jun 8 23:00:49 backupnas collectd[1574]: statfs(/mnt/backupnas/Data1/iocage/releases) failed: No such file or directory
Jun 8 23:00:59 backupnas collectd[1574]: statfs(/mnt/backupnas/Data1/iocage/templates) failed: No such file or directory
-Recursive is enabled
-Enabling or disabling "Replicate from scratch if incremental is not possible" makes no difference
-If I delete the dataset on the backup server then manually run the backup task it completes without error and does not spam the console. But the next scheduled run generates the same 4 errors.
-I can see the snapshots on the backup server gui, but ssh'ing in and navigating to the /mnt/backupnas/Data1/iocage/ directory shows defaults.json, defaults_backup.json and defaults_rc.json, no other files or directories.
warriorcookie
Member
any ideas?
Samuel Tai
Are the jails active during the replication cycle?
warriorcookie
Member
Samuel Tai
Try shutting the jails down. This is probably something like needing to quiesce VMs before snapshotting them.
adrianwi
Neophyte Sage
I'm seeing a similar issue with iocage replication, as described here
Are you sure they are completing correctly? I'm not seeing the iocage folders when I SSH into my target machine, although they are showing as there in the WUI. Whenever they change replication, it tends to be a mess for a few releases afterwards :(
ps: the jails don't need to be stopped as the replication is moving snapshots already taken
warriorcookie
Member
Stopping the jails actually generated more errors at the console.
The sending FreeNAS box generates no errors and I can see the snapshots listed on the receiving "Backup" FreeNAS. The errors are on the console of the receiving box only and the directory is empty except those .json files.
It is strange because the first replication always completes successfully. If I delete the dataset and manually run the replication task it completes without error. It's all my subsequent nightlys that fail.
warriorcookie
Member
warriorcookie
Member
adrianwi
Neophyte Sage
Yes, I think the replication is working but it's hiding nested datasets/zvols on the target machine.
Hopefully something they can fix for U4
warriorcookie
Member
It seems to be working, but yes it's hiden until I reboot the backup server. Then I can browse until the next replication...
Really frustrating as ZFS send is a staple backup tool for FreeNAS. When I have more time I should create a new dataset to test restoring a backup from a child dataset and make sure it works. I do offsite nightlies too using the cloud backup feature so I'm not super worried.
warriorcookie
Member
FYI, bug is marked resolved and seems the fix will be pushed in the next update.
warriorcookie
Member
11.3-U4.1 seems to have resolved the issue.
adrianwi
Neophyte Sage
Yes, it resolved this for me.
