ZFS pool went crazy after improper drive replacement
warpik
Hello.
Recently I had 1 drive dead in my pool. In addition to dead drive - wrong drive had been pulled from live storage. Then good drive had been pushed back and bad drive replaced.
Although - pool now can't reconstruct itself.
But, luckily (hopefully) - it is a mirrored RAID10 and all those drives were in same part of mirror, so I suppose that data is intact. But zfs can't rebuild itself. May I manually recreate part of mirror? If yes - how?
Screenshot of current status attached.
garm
It’s not a “RAID10”-like schema. You have two RAIDZ1 vdevs. One of which have 2 unavailable drives. A dual RAIDZ1 vdev pool is closer to something like RAID50. But it’s best to not use the “RAID” terminology altogether.
You are in a very bad situation and hopefully someone will be able to guide you. I will not however due to the risk of data loss with every action from now on.
Also, when you have sorted this out you should consider another topography. Running RAIDZ1 is not adequate redundancy.
warpik
But if its a raid 50 - this mean that there 2 "big volumes" , where system should be able to live if one of half is dead, no ?
I kinda said good bye to data already, we have a backup of all of this ... but restoring procedure could be very long, thus trying to save this if possible.
Bidule0hm
Server Electronics Sorcerer
No, it's like a RAID 50, not a RAID 51, so if you lose one part the whole volume is lost.
You are losing sectors on the drives (that's why it's very slow) faster than you can rebuild the data so to me this pool is lost, be ready to restore from backup. And before restoring I recommend you to destroy and rebuild the pool as two RAID-Z2 vdevs of 8 drives instead of RAID-Z1.
Also, do you have SMART tests correctly configured?
And what's the output of smartctl -a /dev/adaX for each drive (please use the code tags to make it readable)?
warpik
Um... Could you please reexplain in more simple words what is RAID-Z2? Or where i can read about these RAID levels?
Smart is proper, at least in GUI I see all reports per each drive without issues.
/dev/ada is a SSD-on-a-stick device, in SATA port.
All rest of drives using HBA and marked as daX
root@store001hw:~ # smartctl -a /dev/da
da0%	da1%	da10p2% da11p2% da12p2% da13p2% da14p2% da15p2% da2%	da3%	da4%	da5%	da6%	da7%	da8%	da9%
da0p1%  da10%   da11%   da12%   da13%   da14%   da15%   da1p1%  da2p1%  da3p1%  da4p1%  da5p1%  da6p1%  da7p1%  da8p1%  da9p1%
da0p2%  da10p1% da11p1% da12p1% da13p1% da14p1% da15p1% da1p2%  da2p2%  da3p2%  da4p2%  da5p2%  da6p2%  da7p2%  da8p2%  da9p2%
root@store001hw:~ # smartctl -a /dev/da5
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Seagate Constellation ES.3
Device Model:	 ST2000NM0033-9ZM175
Serial Number:	Z1X28SAM
LU WWN Device Id: 5 000c50 066c8dd42
Firmware Version: SN03
User Capacity:	2,000,398,934,016 bytes [2.00 TB]
Sector Size:	  512 bytes logical/physical
Rotation Rate:	7200 rpm
Form Factor:	  3.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Thu Mar  8 07:33:35 2018 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
										was completed without error.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(  592) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   1) minutes.
Extended self-test routine
recommended polling time:		( 253) minutes.
Conveyance self-test routine
recommended polling time:		(   2) minutes.
SCT capabilities:			  (0x50bd) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000f   083   063   044	Pre-fail  Always	   -	   218230036
  3 Spin_Up_Time			0x0003   095   095   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   36
  5 Reallocated_Sector_Ct   0x0033   100   100   010	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2201036203
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27639
 10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   32
184 End-to-End_Error		0x0032   100   100   099	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   100   100   000	Old_age   Always	   -	   0
188 Command_Timeout		 0x0032   100   100   000	Old_age   Always	   -	   0
189 High_Fly_Writes		 0x003a   099   099   000	Old_age   Always	   -	   1
190 Airflow_Temperature_Cel 0x0022   070   051   045	Old_age   Always	   -	   30 (Min/Max 26/30)
191 G-Sense_Error_Rate	  0x0032   100   100   000	Old_age   Always	   -	   0
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   31
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1183
194 Temperature_Celsius	 0x0022   030   049   000	Old_age   Always	   -	   30 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   060   011   000	Old_age   Always	   -	   218230036
197 Current_Pending_Sector  0x0012   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0010   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Bidule0hm
warpik
I'm using 9207-8i of Broadcom (2308 LSI), based on SuperMicro chassis with Intel(R) Xeon(R) CPU E5-1620 v2 and 16Gb of RAM
For each drive? It will be long post =)
# for i in 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15; do echo drive $i ; echo "CODE]" ; /usr/local/sbin/smartctl -a /dev/da$i; echo "/CODE]"; done
drive 0
Serial Number:	Z1X28QEC
LU WWN Device Id: 5 000c50 066c919c1
Local Time is:	Thu Mar  8 08:53:59 2018 EST
										been run.
										command.
										power-saving mode.
recommended polling time:		( 246) minutes.
  1 Raw_Read_Error_Rate	 0x000f   078   063   044	Pre-fail  Always	   -	   60309905
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   259
  7 Seek_Error_Rate		 0x000f   090   060   030	Pre-fail  Always	   -	   1209193902
  9 Power_On_Hours		  0x0032   070   070   000	Old_age   Always	   -	   26962
189 High_Fly_Writes		 0x003a   100   100   000	Old_age   Always	   -	   0
190 Airflow_Temperature_Cel 0x0022   067   048   045	Old_age   Always	   -	   33 (Min/Max 29/33)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   26
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   804
194 Temperature_Celsius	 0x0022   033   052   000	Old_age   Always	   -	   33 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   060   009   000	Old_age   Always	   -	   60309905
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 1
Serial Number:	Z1X28QC3
LU WWN Device Id: 5 000c50 066c91c37
										been run.
										command.
										power-saving mode.
recommended polling time:		( 247) minutes.
  1 Raw_Read_Error_Rate	 0x000f   083   063   044	Pre-fail  Always	   -	   224820172
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2107089060
  9 Power_On_Hours		  0x0032   070   070   000	Old_age   Always	   -	   27137
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   31
189 High_Fly_Writes		 0x003a   098   098   000	Old_age   Always	   -	   2
190 Airflow_Temperature_Cel 0x0022   069   050   045	Old_age   Always	   -	   31 (Min/Max 28/32)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   30
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1162
194 Temperature_Celsius	 0x0022   031   050   000	Old_age   Always	   -	   31 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   059   010   000	Old_age   Always	   -	   224820172
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 2
Serial Number:	Z1X28QQG
LU WWN Device Id: 5 000c50 066c8f7f0
Local Time is:	Thu Mar  8 08:54:00 2018 EST
										been run.
data collection:				(  584) seconds.
										command.
										power-saving mode.
recommended polling time:		( 240) minutes.
  1 Raw_Read_Error_Rate	 0x000f   079   063   044	Pre-fail  Always	   -	   91493440
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   266
  7 Seek_Error_Rate		 0x000f   090   060   030	Pre-fail  Always	   -	   1207109482
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27290
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   39
190 Airflow_Temperature_Cel 0x0022   070   051   045	Old_age   Always	   -	   30 (Min/Max 27/32)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   33
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   824
194 Temperature_Celsius	 0x0022   030   049   000	Old_age   Always	   -	   30 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   060   009   000	Old_age   Always	   -	   91493440
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 3
Serial Number:	Z1X28QNJ
LU WWN Device Id: 5 000c50 066c901f3
										been run.
										command.
										power-saving mode.
recommended polling time:		( 252) minutes.
  1 Raw_Read_Error_Rate	 0x000f   078   063   044	Pre-fail  Always	   -	   62956247
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   35
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2187376922
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27643
190 Airflow_Temperature_Cel 0x0022   068   052   045	Old_age   Always	   -	   32 (Min/Max 29/33)
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1184
194 Temperature_Celsius	 0x0022   032   048   000	Old_age   Always	   -	   32 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   060   011   000	Old_age   Always	   -	   62956247
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 4
Serial Number:	Z1X28QHW
LU WWN Device Id: 5 000c50 066c9092f
Local Time is:	Thu Mar  8 08:54:01 2018 EST
										been run.
										command.
										power-saving mode.
recommended polling time:		( 243) minutes.
  1 Raw_Read_Error_Rate	 0x000f   082   063   044	Pre-fail  Always	   -	   181607829
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2017712010
190 Airflow_Temperature_Cel 0x0022   070   046   045	Old_age   Always	   -	   30 (Min/Max 26/33)
194 Temperature_Celsius	 0x0022   030   054   000	Old_age   Always	   -	   30 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   022   011   000	Old_age   Always	   -	   181607829
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 5
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   076   063   044	Pre-fail  Always	   -	   45748067
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2202324998
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27641
190 Airflow_Temperature_Cel 0x0022   072   051   045	Old_age   Always	   -	   28 (Min/Max 26/30)
194 Temperature_Celsius	 0x0022   028   049   000	Old_age   Always	   -	   28 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   060   011   000	Old_age   Always	   -	   45748067
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
warpik
drive 6
Serial Number:	Z1X28QCW
LU WWN Device Id: 5 000c50 066c91b00
										been run.
										command.
										power-saving mode.
recommended polling time:		( 248) minutes.
  1 Raw_Read_Error_Rate	 0x000f   083   063   044	Pre-fail  Always	   -	   205405904
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   30
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2056181137
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27630
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   27
190 Airflow_Temperature_Cel 0x0022   068   047   045	Old_age   Always	   -	   32 (Min/Max 30/35)
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1176
194 Temperature_Celsius	 0x0022   032   053   000	Old_age   Always	   -	   32 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   054   010   000	Old_age   Always	   -	   205405904
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 7
Serial Number:	Z1X28TD0
LU WWN Device Id: 5 000c50 066c882e0
Local Time is:	Thu Mar  8 08:54:02 2018 EST
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   077   063   044	Pre-fail  Always	   -	   50423509
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2062295341
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27631
190 Airflow_Temperature_Cel 0x0022   070   048   045	Old_age   Always	   -	   30 (Min/Max 28/34)
194 Temperature_Celsius	 0x0022   030   052   000	Old_age   Always	   -	   30 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   048   009   000	Old_age   Always	   -	   50423509
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 8
Serial Number:	Z1X27F15
LU WWN Device Id: 5 000c50 066bb65da
										been run.
										command.
										power-saving mode.
recommended polling time:		( 245) minutes.
  1 Raw_Read_Error_Rate	 0x000f   081   063   044	Pre-fail  Always	   -	   154757952
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   29
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2029565788
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   26
188 Command_Timeout		 0x0032   100   099   000	Old_age   Always	   -	   1
190 Airflow_Temperature_Cel 0x0022   071   046   045	Old_age   Always	   -	   29 (Min/Max 27/33)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   25
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1175
194 Temperature_Celsius	 0x0022   029   054   000	Old_age   Always	   -	   29 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   052   009   000	Old_age   Always	   -	   154757952
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 9
Serial Number:	Z1X28YP6
LU WWN Device Id: 5 000c50 066c76f41
										been run.
										command.
										power-saving mode.
recommended polling time:		( 250) minutes.
  1 Raw_Read_Error_Rate	 0x000f   079   063   044	Pre-fail  Always	   -	   93702423
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2077111239
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27628
190 Airflow_Temperature_Cel 0x0022   072   051   045	Old_age   Always	   -	   28 (Min/Max 27/32)
195 Hardware_ECC_Recovered  0x001a   050   009   000	Old_age   Always	   -	   93702423
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 10
Serial Number:	Z1X28RLL
LU WWN Device Id: 5 000c50 066c8df1a
										been run.
										command.
										power-saving mode.
recommended polling time:		( 265) minutes.
  1 Raw_Read_Error_Rate	 0x000f   081   063   044	Pre-fail  Always	   -	   154646727
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   33
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2201685095
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   29
190 Airflow_Temperature_Cel 0x0022   066   049   045	Old_age   Always	   -	   34 (Min/Max 31/37)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   28
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1180
194 Temperature_Celsius	 0x0022   034   051   000	Old_age   Always	   -	   34 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   052   010   000	Old_age   Always	   -	   154646727
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
warpik
drive 11
Serial Number:	Z1X28SXR
LU WWN Device Id: 5 000c50 066c8ab17
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   082   063   044	Pre-fail  Always	   -	   189441636
  5 Reallocated_Sector_Ct   0x0033   097   097   010	Pre-fail  Always	   -	   611
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2013715177
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27629
188 Command_Timeout		 0x0032   100   099   000	Old_age   Always	   -	   4295032833
190 Airflow_Temperature_Cel 0x0022   066   046   045	Old_age   Always	   -	   34 (Min/Max 30/36)
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1178
194 Temperature_Celsius	 0x0022   034   054   000	Old_age   Always	   -	   34 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   038   010   000	Old_age   Always	   -	   189441636
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 12
Serial Number:	Z1X28TC9
LU WWN Device Id: 5 000c50 066c8823e
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   082   063   044	Pre-fail  Always	   -	   192010591
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   32
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2033876819
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   28
190 Airflow_Temperature_Cel 0x0022   067   046   045	Old_age   Always	   -	   33 (Min/Max 30/36)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   27
194 Temperature_Celsius	 0x0022   033   054   000	Old_age   Always	   -	   33 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   050   009   000	Old_age   Always	   -	   192010591
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 13
Serial Number:	Z1X28QBW
LU WWN Device Id: 5 000c50 066c91cb3
Local Time is:	Thu Mar  8 08:54:03 2018 EST
										been run.
										command.
										power-saving mode.
recommended polling time:		( 249) minutes.
  1 Raw_Read_Error_Rate	 0x000f   082   063   044	Pre-fail  Always	   -	   171998543
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2065308686
190 Airflow_Temperature_Cel 0x0022   068   051   045	Old_age   Always	   -	   32 (Min/Max 28/34)
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1179
194 Temperature_Celsius	 0x0022   032   049   000	Old_age   Always	   -	   32 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   052   003   000	Old_age   Always	   -	   171998543
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 14
Serial Number:	Z1X0YPZC
LU WWN Device Id: 5 000c50 05d1c28e0
Firmware Version: SN04
										been run.
										command.
										power-saving mode.
recommended polling time:		( 241) minutes.
  1 Raw_Read_Error_Rate	 0x000f   081   064   044	Pre-fail  Always	   -	   128612145
  3 Spin_Up_Time			0x0003   100   100   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   1
  7 Seek_Error_Rate		 0x000f   081   060   030	Pre-fail  Always	   -	   135668545
  9 Power_On_Hours		  0x0032   097   097   000	Old_age   Always	   -	   2807
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   1
190 Airflow_Temperature_Cel 0x0022   071   069   045	Old_age   Always	   -	   29 (Min/Max 22/31)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   0
194 Temperature_Celsius	 0x0022   029   040   000	Old_age   Always	   -	   29 (0 22 0 0 0)
195 Hardware_ECC_Recovered  0x001a   060   026   000	Old_age   Always	   -	   128612145
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 15
Serial Number:	Z1X33VWE
LU WWN Device Id: 5 000c50 079382375
Firmware Version: SN06
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   081   063   044	Pre-fail  Always	   -	   162243797
  3 Spin_Up_Time			0x0003   099   099   000	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   080   060   045	Pre-fail  Always	   -	   108156774
  9 Power_On_Hours		  0x0032   100   100   000	Old_age   Always	   -	   131
190 Airflow_Temperature_Cel 0x0022   070   068   040	Old_age   Always	   -	   30 (Min/Max 24/32)
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   9
194 Temperature_Celsius	 0x0022   030   040   000	Old_age   Always	   -	   30 (0 22 0 0 0)
195 Hardware_ECC_Recovered  0x001a   059   030   000	Old_age   Always	   -	   162243797
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Bidule0hm
Earlier I asked if you have the SMART tests correctly configured but as none of the drives has ever had a SMART tests I guess they aren't. The problem is that without tests they may be some bad sectors that are undetected. So I'll list after this sentence what I see that can be a concern but you'll need to execute a long test ( smartctl -t long /dev/daX) for each drive and repost the outputs of smartctl once the tests are finished (about 4 hours on your drives) to have up to date data we can analyse.
da0 OK
da1 OK
da2 OK
da3 OK
da4 OK
da5 OK
da6 OK
da7 OK
da8 one command timeout, but that's nothing to worry so OK
da9 OK
da10 OK
da11 611 reallocated sectors: this drive is dying. And more than 4 billions command timeouts; it's the drive or the cable (but as it has a lot of bad sectors and the UDMA CRC error count is 0 I guess it's because of the drive, not the cable)
da12 OK
da13 OK
da14 OK
da15 OK
warpik
I see.
I thought that FreeNAS have this practice (test scheduled) at default and should be shoot a warning ...
I agree with you that da11 probably need to replace proactively, btw =)
Also, this extended test might be run on all drives at same or need to be done one by one ?
Redcoat
You can run it on all drives simultaneously.
For the SMART tests, you must define the tests you want and the frequency - see the manual at Section 6.5 http://doc.freenas.org/11/tasks.html#s-m-a-r-t-tests
Also, you have set FreeNAS up correctly to "shoot a warning". I suggest that you read the manual from end-to-end and also study the Resources section here - look for the post for the scripts by @Spearfoot that will deal with "shooting warnings" - included in that is a link to a series of scripts by your contributor @Bidule0hm that you will likely find helpful, too.
warpik
Testing has begun.
Please wait 247 minutes for test to complete.
I do read those manual, but still - its too much of data , can't remember everything. Especially if not working with this on daily basis =)
Thanks for info to read! Will look into this .
warpik
drive 0
Local Time is:	Mon Mar 12 05:30:26 2018 EDT
Self-test execution status:	  ( 249) Self-test routine in progress...
										90% of test remaining.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   081   063   044	Pre-fail  Always	   -	   131159457
  7 Seek_Error_Rate		 0x000f   090   060   030	Pre-fail  Always	   -	   1299941453
  9 Power_On_Hours		  0x0032   070   070   000	Old_age   Always	   -	   27054
190 Airflow_Temperature_Cel 0x0022   068   048   045	Old_age   Always	   -	   32 (Min/Max 29/33)
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   808
194 Temperature_Celsius	 0x0022   032   052   000	Old_age   Always	   -	   32 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   059   009   000	Old_age   Always	   -	   131159457
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline	Self-test routine in progress 90%	 27054		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 1
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   082   063   044	Pre-fail  Always	   -	   188421685
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2197724123
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27229
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1166
195 Hardware_ECC_Recovered  0x001a   058   010   000	Old_age   Always	   -	   188421685
No Errors Logged
# 1  Extended offline	Self-test routine in progress 90%	 27229		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 2
Local Time is:	Mon Mar 12 05:30:27 2018 EDT
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   084   063   044	Pre-fail  Always	   -	   242533278
  7 Seek_Error_Rate		 0x000f   090   060   030	Pre-fail  Always	   -	   1297853263
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27382
190 Airflow_Temperature_Cel 0x0022   071   051   045	Old_age   Always	   -	   29 (Min/Max 27/32)
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   827
194 Temperature_Celsius	 0x0022   029   049   000	Old_age   Always	   -	   29 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   059   009   000	Old_age   Always	   -	   242533278
No Errors Logged
# 1  Extended offline	Self-test routine in progress 90%	 27382		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 3
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   083   063   044	Pre-fail  Always	   -	   230985896
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2278537565
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27735
190 Airflow_Temperature_Cel 0x0022   069   052   045	Old_age   Always	   -	   31 (Min/Max 29/33)
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1188
194 Temperature_Celsius	 0x0022   031   048   000	Old_age   Always	   -	   31 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   059   011   000	Old_age   Always	   -	   230985896
No Errors Logged
# 1  Extended offline	Self-test routine in progress 90%	 27735		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 4
Local Time is:	Mon Mar 12 05:30:28 2018 EDT
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   083   063   044	Pre-fail  Always	   -	   219720839
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2026287871
190 Airflow_Temperature_Cel 0x0022   071   046   045	Old_age   Always	   -	   29 (Min/Max 26/33)
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1187
195 Hardware_ECC_Recovered  0x001a   023   011   000	Old_age   Always	   -	   219720839
No Errors Logged
# 1  Extended offline	Completed without error	   00%	 27718		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 5
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   076   063   044	Pre-fail  Always	   -	   42399916
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2293012430
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27732
190 Airflow_Temperature_Cel 0x0022   073   051   045	Old_age   Always	   -	   27 (Min/Max 26/30)
194 Temperature_Celsius	 0x0022   027   049   000	Old_age   Always	   -	   27 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   058   011   000	Old_age   Always	   -	   42399916
No Errors Logged
# 1  Extended offline	Self-test routine in progress 90%	 27732		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
warpik
drive 6
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   078   063   044	Pre-fail  Always	   -	   59973648
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2064891571
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27722
195 Hardware_ECC_Recovered  0x001a   063   010   000	Old_age   Always	   -	   59973648
No Errors Logged
# 1  Extended offline	Completed without error	   00%	 27705		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 7
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   081   063   044	Pre-fail  Always	   -	   140557890
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2070876203
195 Hardware_ECC_Recovered  0x001a   031   009   000	Old_age   Always	   -	   140557890
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 8
Local Time is:	Mon Mar 12 05:30:29 2018 EDT
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   070   063   044	Pre-fail  Always	   -	   10819025
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2038156779
195 Hardware_ECC_Recovered  0x001a   062   009   000	Old_age   Always	   -	   10819025
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 9
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   082   063   044	Pre-fail  Always	   -	   187045024
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2085752915
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27720
195 Hardware_ECC_Recovered  0x001a   051   009   000	Old_age   Always	   -	   187045024
No Errors Logged
# 1  Extended offline	Completed without error	   00%	 27703		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 10
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   066   063   044	Pre-fail  Always	   -	   4973571
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2210985052
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27723
195 Hardware_ECC_Recovered  0x001a   059   010   000	Old_age   Always	   -	   4973571
No Errors Logged
# 1  Extended offline	Completed without error	   00%	 27706		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
warpik
drive 11
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   083   063   044	Pre-fail  Always	   -	   229636610
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2022814941
  9 Power_On_Hours		  0x0032   069   069   000	Old_age   Always	   -	   27721
195 Hardware_ECC_Recovered  0x001a   023   010   000	Old_age   Always	   -	   229636610
No Errors Logged
# 1  Extended offline	Completed without error	   00%	 27704		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 12
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   076   063   044	Pre-fail  Always	   -	   47705206
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2042497645
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   1182
195 Hardware_ECC_Recovered  0x001a   062   009   000	Old_age   Always	   -	   47705206
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 13
										been run.
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   073   063   044	Pre-fail  Always	   -	   23026904
  7 Seek_Error_Rate		 0x000f   093   060   030	Pre-fail  Always	   -	   2073899401
190 Airflow_Temperature_Cel 0x0022   069   051   045	Old_age   Always	   -	   31 (Min/Max 28/34)
194 Temperature_Celsius	 0x0022   031   049   000	Old_age   Always	   -	   31 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   061   003   000	Old_age   Always	   -	   23026904
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 14
Local Time is:	Mon Mar 12 05:30:30 2018 EDT
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   083   064   044	Pre-fail  Always	   -	   223467376
  7 Seek_Error_Rate		 0x000f   083   060   030	Pre-fail  Always	   -	   226272584
  9 Power_On_Hours		  0x0032   097   097   000	Old_age   Always	   -	   2899
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   121
195 Hardware_ECC_Recovered  0x001a   059   026   000	Old_age   Always	   -	   223467376
No Errors Logged
# 1  Extended offline	Self-test routine in progress 90%	  2899		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
drive 15
										command.
										power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   084   063   044	Pre-fail  Always	   -	   241861683
  7 Seek_Error_Rate		 0x000f   082   060   045	Pre-fail  Always	   -	   198919751
  9 Power_On_Hours		  0x0032   100   100   000	Old_age   Always	   -	   222
190 Airflow_Temperature_Cel 0x0022   071   068   040	Old_age   Always	   -	   29 (Min/Max 24/32)
195 Hardware_ECC_Recovered  0x001a   059   030   000	Old_age   Always	   -	   241861683
No Errors Logged
# 1  Extended offline	Self-test routine in progress 90%	   222		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
warpik
Couple of drives still testing (after 24 hours =\ )
But it looks like only single drive in warning with large reallocated sectors count - and those that not completed yet - i believe everything ok.
warpik
Hmm, what is benefit of making 2 RAID-Z2 vdevs ? To be able sustainability of 4 drive in total (2 maximum in each of Vdevs?), right ?
Bidule0hm
Ok, so:
da0 test still in progress
da1 test still in progress
da2 test still in progress
da3 test still in progress
da4 OK
da5 test still in progress
da6 OK
da7 OK
da8 OK
da9 OK
da10 OK
da11 failing now, same as before
da12 OK
da13 OK
da14 test still in progress
da15 test still in progress
I can't say anything for the drives who are still in progress.
Yes, it would have avoided your situation where a second failing drive create corruption while you're resilvering a first failed drive, we recommend RAID-Z2 over RAID-Z1 exactly for this reason.
But I can guess this drive is failing since a few weeks if not months and the real problem is that you didn't setup the SMART tests and/or the FreeNAS alerts correctly so you didn't receive the warning emails you should have received.
warpik
So, all discs passed SMART tests
" ; /usr/local/sbin/smartctl -a /dev/da$i | grep Extended ; echo "
"; done
drive 0
# 1  Extended offline	Completed without error	   00%	 27063		 -
drive 1
# 1  Extended offline	Completed without error	   00%	 27238		 -
drive 2
# 1  Extended offline	Completed without error	   00%	 27391		 -
drive 3
# 1  Extended offline	Completed without error	   00%	 27744		 -
drive 4
drive 5
# 1  Extended offline	Completed without error	   00%	 27741		 -
drive 6
drive 7
drive 8
drive 9
drive 10
drive 11
drive 12
drive 13
drive 14
# 1  Extended offline	Completed without error	   00%	  2908		 -
drive 15
# 1  Extended offline	Completed without error	   00%	   231		 -
