zmanbb
- Jul 4, 2013
Hi
After power outage one of my ZFS shares cannot be mounted any more.
I have three volumes (all on the same physical drive):
1. RAID -> /mnt/RAID
2. RAID/datoteke -> /mnt/RAID/datoteke
3. RAID/dokumenti -> /mnt/RAID/dokumenti
When trying to mount RAID/dokumenti, error occurs: "cannot mount 'RAID/dokumenti': Input/output error".
Has anyone expirienced something similar? How can I fix this error?
Thank you
After running scrub on the volume the "zpool status -v" output is:
Thank you
[root@freenas] /var/log# zfs mount RAID/dokumenti cannot mount 'RAID/dokumenti': Input/output error [root@freenas] /var/log# zfs list NAME USED AVAIL REFER MOUNTPOINT RAID 13.5G 439G 128K /mnt/RAID RAID/datoteke 9.57G 439G 9.57G /mnt/RAID/datoteke RAID/dokumenti 3.95G 439G 3.95G /mnt/RAID/dokumenti [root@freenas] /var/log# gpart show => 34 976562109 da0 GPT (466G) 34 94 - free - (47K) 128 4194304 1 freebsd-swap (2.0G) 4194432 972367711 2 freebsd-zfs (464G) => 63 15644790 da1 MBR (7.5G) 63 1930257 1 freebsd [active] (943M) 1930320 63 - free - (32K) 1930383 1930257 2 freebsd (943M) 3860640 3024 3 freebsd (1.5M) 3863664 41328 4 freebsd (20M) 3904992 11739861 - free - (5.6G) => 63 488281185 ada0 MBR (233G) 63 488279547 1 freebsd [active] (233G) 488279610 1638 - free - (819K) => 0 1930257 da1s1 BSD (943M) 0 16 - free - (8.0K) 16 1930241 1 !0 (943M) => 0 1930257 da1s2 BSD (943M) 0 16 - free - (8.0K) 16 1930241 1 !0 (943M)
[root@freenas] /var/log# zpool status -v pool: RAID state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://www.sun.com/msg/ZFS-8000-8A scrub: scrub completed after 0h1m with 2 errors on Thu Jul 4 13:15:07 2013 config: NAME STATE READ WRITE CKSUM RAID ONLINE 0 0 11 gptid/d3fca758-d413-11e1-a76d-001143fcddf4 ONLINE 0 0 102 errors: Permanent errors have been detected in the following files: RAID/dokumenti:<0x0>
