FreeNAS ZFS Fails to import existing ZFS Pool
SunSdSe
Good Day,
I have a previous ZFS pool configuration running under a different NAS software. I installed 8.0.4 64bit to a USB stick and I was unable to import the ZFS volumes.
The ZFS can mount the volume just fine and use it correctly, however, I can't import it into the FreeNAS 8.0.4. Below is the volume information.
How do I get this volume infomation into the FreeNAS menu system?
Thanks,
John
[root@freenas] ~# df -h
Filesystem Size Used Avail Capacity Mounted on
/dev/ufs/FreeNASs1a 927M 379M 474M 44% /
devfs 1.0K 1.0K 0B 100% /dev
/dev/md0 4.6M 1.9M 2.3M 44% /etc
/dev/md1 824K 4.0K 754K 1% /mnt
/dev/md2 149M 8.2M 129M 6% /var
/dev/ufs/FreeNASs4 20M 408K 18M 2% /data
Home 71G 2.1G 69G 3% /mnt/Home
Data 1.7T 21K 1.7T 0% /mnt/Data
[root@freenas] ~# zpool list
NAME SIZE USED AVAIL CAP HEALTH ALTROOT
Data 1.73T 84K 1.73T 0% ONLINE -
Home 72.5G 2.98G 69.5G 4% ONLINE -
[root@freenas] ~# zpool status
pool: Data
state: ONLINE
scrub: none requested
NAME STATE READ WRITE CKSUM
Data ONLINE 0 0 0
ada1d ONLINE 0 0 0
errors: No known data errors
pool: Home
state: ONLINE
Home ONLINE 0 0 0
mirror ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
ada1b ONLINE 0 0 0
[root@freenas] ~# gpart show
=> 63 7831467 da0 MBR (3.7G)
63 1930257 1 freebsd [active] (943M)
1930320 63 - free - (32K)
1930383 1930257 2 freebsd (943M)
3860640 3024 3 freebsd (1.5M)
3863664 41328 4 freebsd (20M)
3904992 3926538 - free - (1.9G)
=> 34 156249933 ada0 GPT (75G)
34 94 - free - (47K)
128 4194304 1 freebsd-swap (2.0G)
4194432 152055535 2 freebsd-ufs (73G)
=> 0 3907029168 ada1 BSD (1.8T)
0 128 - free - (64K)
156249967 3750779201 4 freebsd-ufs (1.7T)
=> 0 1930257 da0s1 BSD (943M)
0 16 - free - (8.0K)
16 1930241 1 !0 (943M)
[root@freenas] ~#
