After updating FreeNAS and upgrading my zpools, I noticed that not all volumes from one of my zpools were available after unlocking the pool. Also, the GUI never completed the unlock action.
I rebooted and tried again for a few times, but without success. The unlock never completed.
I tried to scrub the pool - there were no errors found and the behavior did not change.
So, I decided to investigate. I did a manual "geli attach" for all 8 drives in the pool. Then I did a "zpool import -N" for the pool. Finally, I mounted the volumes one by one. Strangely, there is one volume that causes "zfs mount" to hang indefinitely. There is no action on the HDDs and no IO in "zpool iostat". All other volumes on the same zpool are working just fine. The pool consists of only one raidz2-0 with 8 HDDs
Any advice? I am happy to provide all the information that might be helpful to debug this.
Thanks!
Thanks!
