Zabbix plugin not reachable
stuffedmky
Hi everyone!
New TrueNAS user since a couple of months. Installed as VM on a Proxmox server.
I've got Plex installed as a plugin and that works great. But I also tried the Zabbix community plugin and cant get it to work.
It installs just fine, and I get the post-installation notes and all that, but how do I reach it?
I cant find what ports the admin portal is exposed on, the post-install screen just showed the IP to my TrueNAS, and that ofcourse doesnt work since that serves the truenas gui =)
Any suggestions?
Thanks in advance!
stuffedmky
Didnt find a way to edit my post. But the real question is, how do I get the plugin to use host network? I was able to change this with Plex but cant find how to do it with Zabbix. That setting seems to be grayed out?
Venzeles
During installation, you specify an IP address.
After installation, the plugin should be available by IP address.
Example: https://192.168.1.2:30001
I am facing the sames issue: installed the Zabbix Server Community Plugin and now I cannot access the web UI.
The reason is that Zabbix installation did not create a separate port to listen to and now it is trying to use the same IP & normal http(s) port which is already being used by Truenas Core itself.
I installed the Nextcloud plugin to test and that installation created another port and I can access nextcloud with the IP and port.
I tried to look around if I could create a rule from Truenas network settings but did not find a place where the nextcloud port would have been configured. Should I do something in the Zabbix jail console?
