(Yet another) Node 304 Build Validation
creekmor
Hello! I have been reading through a number of other builds and I am fairly confident in my budget build, but I would still appreciate someone with more experience to give me a warm fuzzy that everything will work as I expect.
I have no illusions that I am going to be transcoding bluray rips in plex and serving out active directory and samba shares to 50 users. I hope to use it as a cheap, low power usage file server to hold and have multiple copies of my critical data (family pictures/videos, etc).
CPU: Intel Pentium G3220
RAM: Crucial 16GB (2 x 8GB) 240-Pin DDR3 SDRAM ECC
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148770
MOBO: ASRock Motherboard, Mini ITX DDR3 1066 LGA 1150 E3C224D2I
PSU: Seasonic 360W 80PLUS Gold
HDD: A couple of WD Reds X TB Mirrored (Still trying to determine space needs)
BOOT: SanDisk Cruzer Fit 8GB (On the super cool internal USB)
Any and all input is greatly appreciated!
Fraoch
Looks really good.
You may want to consider a second USB drive so you have mirrored boot drives.
Fraoch
creekmor
I like it. I have Amazon prime, so 6 more bucks is worth the added benefit of not having to configure everything again if a USB fails.
Fraoch
Of course you should also keep a backup of your configuration database somewhere too. Reinstalling is a simple matter of installing a fresh OS onto a new stick, auto-importing the pool and loading the backup.
Running off the mirror would be faster and less risky though. :smile:
pschatz100
As long as you are buying new components, I would recommend a 16Gb usb stick instead of 8Gb. 8Gb is OK, but with the new update process for FreeNAS 9.3, 16Gb will give you more headroom for keeping boot images.
creekmor
Noted - Thank you. I thought I remembered seeing 8 somewhere but 16 isn't a big jump in price.
pschatz100
8Gb is the recommended minimum for a boot device under FreeNAS 9.3. However, the new update system stores updates on the boot device and lets you revert to a previous version if an update fails or has a major bug. 16Gb gives you more space to keep old boot images. Just more convenient if you are a frequent updater.
I have an 8Gb stick, so I'm using it. But if I were buying new, I'd buy 16Gb.
joelmusicman
Creekmor: I'm running almost that exact config, except using 6x "desktop" Seagate 3TB hard drives. I have no complaints about anything except the drives I chose. I can confirm that real-time Plex transcoding doesn't work so well, but otherwise it can handle quite a lot.
creekmor
Thanks for the warm fuzzy, Joel. Did you have a hard time with the cable management in the case? I've heard some complaints on making things fit
creekmor
Thanks for the heads up - I'll add one to my list (Actually I think I have some already)
pschatz100
If transcoding is a priority, you would be better off with a Core i3. However, the Pentium is a good choice for basic NAS functions.
creekmor
Could anyone recommend a UPS for this setup? I don't need to power anything else but the NAS on the battery while it shuts down.
Would this do the trick?
It would work. If you're ok with spending a bit more, a pure sinewave UPS might be safer with modern PSUs, but the Back-UPS Pro has been working well for me.
Gonzalo
If you have patience and a bunch of zip ties you can do a good job. See my server here. As @joelmusicman said, the correct order of the components installation is important and a full modular PSU too. Also, I didn't need additional cables for hard drives.
Bidule0hm
Server Electronics Sorcerer
There is Micron and Crucial is Micron ;)
