Many thanks to the participants in this forum. I bought and built a system not too dissimilar to Option2 in my original post above. I thought I would give a quick post-mortem, cover lessons learned, and list out all of the resources that were particularly useful to me in my project.
FINAL SYSTEM
X10SDV-8C-TLN4
128GB RAM
LSI 9211-8i
32GB SATA DOM (boot)
1x 120GB Samsung SSD (for VMs and containers)
7x 6TB Seagate Iron Wolf NAS in RAIDZ2
Seasonic 650-X (gives me head room to add 4x or more internal drives for expansion)
3x 140mm fans
1x Fractal Design R5
Cyberpower CP1000PFCLCD UPS 1000VA / 600 watt pure sine wave (plenty to support my system plus router, switch, etc)
FreeNAS 10 nightly (locked to FreeNAS-10-MASTER-201702010216 which has good enough support for VMs, Docker, & SMB for my purposes)
Lessons Learned
Oh boy, there were a few.
* Originally I bought the wrong LSI card. I get a 9200-8e for $65 and thought I won the lottery. Turns out the "8e" portion meant it had SFF-8088 ports which are for EXTERNAL connections. This would have been a great card if I had a separate chassis to house my drives. I could use that card to connect to the second box and found out to all of the drives. However, what I really needed (and thought I was getting) was a LSI 9211-8i. I could have rigged up a system with the 9200 card to convert from SF-8088 back to 8087 and feed the cables back into the case via an open PCI slot. After what I spent on this system that seemed pretty foolish, so I got the right card.
* My mistake in #1 came from not understanding the cabling issues. For the 9211-8i I bought a pair of SFF-8087 forward breakout cables to connect the card to the drives. Each SFF-8087 port on the PCI card is handling 4x drives.
* Anti-static straps for the win. I'd owned one for years but it primarily lived in my "misc" parts box. Having one available plus a good set of small phillips-head screwdrivers in my kit was convenient during the build. I'm mostly a software guy so building my own server was a rare treat (this was my first!).
* Having a spare USB keyboard and an old 12" LCD VGA monitor was useful for the initial power-on "smoke" test. After that, IPMI was all I needed.
* IPMI support on OSX is crap. For one, you really need to use Chrome otherwise the HTML5 interface doesn't work in Firefox or Safari. Two, Java support on OSX is junk. I had a Windows10 VM running which allowed me to easily share/export ISO's for mounting via IPMI and Chrome support on Windows is quite good. I could have made this all work on the OSX VM but Windows was just way way easier. BTW, my board initially shipped with IPMI firmware 3.24. You should upgrade immediately to 3.46 (or higher) to get HTML5 support which is SUPER convenient.
* Rufus is a great tool (Windows) for creating bootable FreeDOS USB sticks. Used for running memtest, flashing PCI card hardware, etc.
* Testing FreeNAS out as a VM under vmware was a great way to experiment and lay out a sample system. I recommend using it (or a similar virtual env) if you have access to one.
* Reading (or lurking) these forums for a few weeks or months in advance is very beneficial. I last played with FreeBSD 4 way back when and was already familiar with the... ahem... "prickly nature" of a portion of its community. Asking dumb questions that a 5m forum search or a quick google will answer is not a good way to ingratiate yourself. Do some work ahead of time.
* Burn-in tests are cheap insurance. I ran memtest86+ 5.01 on the system for a week doing a "round robin" between all 16 cores. No failures. Ran cpustress overnight, no failures. Ran
@jgreco's solnet script to stress the disks. Used Uncle Fester's newbie guide to figure out the SMART stuff. I didn't get any failures and have more confidence in the system. I didn't do a 3-6 week burn-in, but this is a home system for a small business so I'm willing to take on a little risk.
* I'll be running a mixed environment with OSX, Windows, Linux, and FreeBSD. All shares will be via Samba. No NFS, no AFS. See resource link below for figuring out SMB permissions. NFS is a tangled mess to keep permissions straight (even with v3 and v4). Apple is dropping/deprecating AFS support. SMB is well supported across all modern OSes so just use it directly.
* FreeNAS nightlies have their ups & downs. I consider myself a power user so I'm comfortable mucking around with beta software, filing bugs, making small software patches, etc. Find a good nightly and rename it (fluffybunny!) so you can roll back to it if a future nightly borks things. Personally, I have a fairly solid nightly that I'm running and have no plans to upgrade until release.
* SMART output via
on FreeBSD has weird reporting for Seagate drives. The RAW_DATA column for Seagates will show a scarily high number so you'll immediately think the drive is failing. Turns out it's a 48-bit number where the top 4 nibbles are the number of failures and the remainder of the number is an always-increasing count of those operations. I recommend running the following command to output that decimal as hex and make the number more easily parsed.
smartctl -A --vendorattribute=N,hex48 /dev/da0
RESOURCES
Here are links to what I thought were useful threads or resources along with a few notes. Many of these are stickies in "Help & Support/Hardware" forum.
* ZFS sizing calculator
https://jsfiddle.net/Biduleohm/paq5u7z5/1/embedded/result/
* X10SDV motherboards (no need to read all 68 pages... read the last 5 or so)
https://forums.servethehome.com/index.php?threads/intel-xeon-d-1500-series-discussion.5036/page-68
* General resource on flashing LSI cards
Instead of using "megarec" utility which isn't always easily available, use "sasflash2.exe -o -e 6" to erase the flash ("e 6" is the magic part).
https://forums.freenas.org/index.php?threads/crossflash-dell-h200e-to-lsi-9200-8e.41307/
* Identify all disks and match the "/dev/da*" entry to a physical drive during the initial build
I also recorded physical position as a comment on each disk description using the GUI.
https://forums.freenas.org/index.php?threads/identify-physical-disks-and-rename-devices.20571/
* Disk burn-in
https://forums.freenas.org/index.php?threads/building-burn-in-and-testing-your-freenas-system.17750/
* Useful videos for figuring out SMB/CIFS permissions
https://forums.freenas.org/index.php?resources/freenas-and-samba-smb-permissions-video.8/
* Improving SMB performance for directories with large numbers of files (still pertinent for FreeNAS 10 too)
See item #4 in first post. Note that FreeNAS 10 disables a few of those attributes but two of them (map_archive and map_readonly) are still enabled. Turn them off via cli using:
/share/smb/ <share name> set map_readonly=false
/share/smb <share name> set map_archive=false
https://forums.freenas.org/index.php?threads/cifs-directory-browsing-slow-try-this.27751/
* Uncle Fester's newbie FreeNAS guide (still relevant even for FreeNAS 10)
https://wiki.freenas.org/index.php/Uncle_Fester's_Guide
