Problem: After initiating a scrub with my 4 HDD's attached via the onboard LSI 2308 the 2308 controller resets causing HDD's drives to drop from the zpool with checksum/read/write errors I assume because the resting 2308 causes read and write errors to the pool/drives which the scrub picks up and therefore removes the drives from the pool.
The LSI 2308 has been flashed to phase 16 IT mode to match the included version 16 driver that both FreeNAS 9.2.1.x and FreeNAS 9.3-REALEASE use.
If the drives are attached via the onboard SATA ports, ZFS scrubs run fine and all drives remain in the pool without error, even after multiple scrubs and after several hundred GB of data was copied to the pool with subsequent scrubs.
I have run long smart tests on all the drives via FreeNAS (SSH into FreeNAS) and plugged the drives into Seagate's and WD's HDD testing programs on windows and all HDD's come back with a pass.
My build was burnt-In with two days of memtest86+, and the Hard Drive Burn-In/Testing thread for all HDD's including short smart test, conveyance tests, long smart, and bad blocks, followed by another long smart test. All HDD's tested fine.
Do you think this is a faulty LSI2308 controller?
Has anyone else experienced the issue with the LSI2308?
I would like to get to the bottom of this as I could use the 6 onboard SATA ports for now and live with it but I chose this motherboard so I could add more drives in the future so I would like to work out what the issue is!
System Configuration Information:
FreeNAS version:
Long smart tests were run on all HDD"s after the above error, and the results are shown below.
1. dmesg
2. pciconf -lv
FreeNAS version:
- FreeNAS-9.3-STABLE-201501301837
- Motherboard: SuperMicro X10SL7-F
- CPU: Intel Xeon E3-1231 v3
- RAM: 16 GB (2x8GB) ECC SAMSUNG 1.35v 1600 MHz (M391B1G73QH0-YK0)
- Storage: 2x 4 TB WD RED + 2x 4TB SEAGATE NAS HDD setup as a GELI encrypted RAIDZ2.
- Boot: Mirrored Sandisk Extreme 32 GB USB3.0 (SDCZ80-032G-GAM46)
1. dmesg
Copyright (c) 1992-2014 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.3-RELEASE-p8 #2 r275790+6365d9c: Sat Jan 24 09:16:18 PST 2015
root@build3.ixsystems.com:/tank/home/jkh/build/93/FN/objs/os-base/amd64/fusion/jkh/93/FN/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz (3400.07-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x306c3 Family = 0x6 Model = 0x3c Stepping = 3
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x7ffafbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,<b11>,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
AMD Features2=0x21<LAHF,ABM>
Standard Extended Features=0x2fbb<GSFSBASE,TSCADJ,SMEP,ENHMOVSB,INVPCID>
TSC: P-state invariant, performance statistics
real memory = 17716740096 (16896 MB)
avail memory = 16481837056 (15718 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <SUPERM SMCI--MB>
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 SMT threads
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
cpu4 (AP): APIC ID: 4
cpu5 (AP): APIC ID: 5
cpu6 (AP): APIC ID: 6
cpu7 (AP): APIC ID: 7
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 5.0 version, truncating length 268 to 256 (20111123/tbfadt-325)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
ispfw: registered firmware <isp_1040>
ispfw: registered firmware <isp_1040_it>
ispfw: registered firmware <isp_1080>
ispfw: registered firmware <isp_1080_it>
ispfw: registered firmware <isp_12160>
ispfw: registered firmware <isp_12160_it>
ispfw: registered firmware <isp_2100>
ispfw: registered firmware <isp_2200>
ispfw: registered firmware <isp_2300>
ispfw: registered firmware <isp_2322>
ispfw: registered firmware <isp_2400>
ispfw: registered firmware <isp_2400_multi>
ispfw: registered firmware <isp_2500>
ispfw: registered firmware <isp_2500_multi>
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <SUPERM SMCI--MB> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 1.1 on pci0
pci2: <ACPI PCI bus> on pcib2
mps0: <LSI SAS2308> port 0xe000-0xe0ff mem 0xf7240000-0xf724ffff,0xf7200000-0xf723ffff irq 17 at device 0.0 on pci2
mps0: Firmware: 16.00.01.00, Driver: 16.00.00.00-fbsd
mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
pci0: <serial bus, USB> at device 20.0 (no driver attached)
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf7514000-0xf75143ff irq 16 at device 26.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> at device 0.0 on pci3
pci4: <ACPI PCI bus> on pcib4
vgapci0: <VGA-compatible display> port 0xd000-0xd07f mem 0xf6000000-0xf6ffffff,0xf7000000-0xf701ffff irq 16 at device 0.0 on pci4
vgapci0: Boot video device
pcib5: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
pci5: <ACPI PCI bus> on pcib5
igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xc000-0xc01f mem 0xf7400000-0xf747ffff,0xf7480000-0xf7483fff irq 18 at device 0.0 on pci5
igb0: Using MSIX interrupts with 5 vectors
igb0: Ethernet address: 0c:c4:7a:30:08:1e
igb0: Bound queue 0 to cpu 0
igb0: Bound queue 1 to cpu 1
igb0: Bound queue 2 to cpu 2
igb0: Bound queue 3 to cpu 3
pcib6: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
pci6: <ACPI PCI bus> on pcib6
igb1: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xb000-0xb01f mem 0xf7300000-0xf737ffff,0xf7380000-0xf7383fff irq 19 at device 0.0 on pci6
igb1: Using MSIX interrupts with 5 vectors
igb1: Ethernet address: 0c:c4:7a:30:08:1f
igb1: Bound queue 0 to cpu 4
igb1: Bound queue 1 to cpu 5
igb1: Bound queue 2 to cpu 6
igb1: Bound queue 3 to cpu 7
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf7513000-0xf75133ff irq 23 at device 29.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci1
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf050-0xf057,0xf040-0xf043,0xf030-0xf037,0xf020-0xf023,0xf000-0xf01f mem 0xf7512000-0xf75127ff irq 19 at device 31.2 on pci0
ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
acpi_button0: <Sleep Button> on acpi0
acpi_button1: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart2: <16550 or compatible> port 0x3e8-0x3ef irq 7 on acpi0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xce000-0xcefff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: CGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
p4tcc4: <CPU Frequency Thermal Control> on cpu4
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
p4tcc5: <CPU Frequency Thermal Control> on cpu5
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
p4tcc6: <CPU Frequency Thermal Control> on cpu6
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
p4tcc7: <CPU Frequency Thermal Control> on cpu7
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
usbus0: 480Mbps High Speed USB v2.0
usbus1: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub2: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.05, addr 2> on usbus0
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.05, addr 2> on usbus1
uhub2: 4 ports with 4 removable, self powered
uhub3: 6 ports with 6 removable, self powered
ugen0.3: <vendor 0x0000> at usbus0
uhub4: <vendor 0x0000 product 0x0001, class 9/0, rev 2.00/0.00, addr 3> on usbus0
uhub4: 4 ports with 3 removable, self powered
ugen0.4: <vendor 0x0557> at usbus0
ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus0
kbd0 at ukbd0
ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus0
ums0: 3 buttons and [Z] coordinates ID=0
ugen1.3: <SanDisk> at usbus1
umass0: <SanDisk Extreme, class 0/0, rev 2.10/0.10, addr 3> on usbus1
umass0: SCSI over Bulk-Only; quirks = 0x0100
umass0:8:0:-1: Attached to scbus8
ugen1.4: <SanDisk> at usbus1
umass1: <SanDisk Extreme, class 0/0, rev 2.10/0.10, addr 4> on usbus1
umass1: SCSI over Bulk-Only; quirks = 0x0100
umass1:9:1:-1: Attached to scbus9
SMP: AP CPU #1 Launched!
da0 at mps0 bus 0 scbus0 target 0 lun 0
da0: <ATA ST4000VN000-1H41 SC44> Fixed Direct Access SCSI-6 device
da0: Serial Number Z301V1ZC
da0: 600.000MB/s transfersSMP: AP CPU #6 Launched!
da0: Command Queueing enabled
da0: 3815447MB (7814037168 512 byte sectors: 255H 63S/T 486401C)
da1 at mps0 bus 0 scbus0 target 1 lun 0
SMP: AP CPU #7 Launched!
da1: <ATA ST4000VN000-1H41 SC44> Fixed Direct Access SCSI-6 device
da1: Serial Number Z302C893
da1: 600.000MB/s transfers
da1: Command Queueing enabled
SMP: AP CPU #2 Launched!
da1: 3815447MB (7814037168 512 byte sectors: 255H 63S/T 486401C)
da2 at mps0 bus 0 scbus0 target 2 lun 0
da2: <ATA WDC WD40EFRX-68W 0A82> Fixed Direct Access SCSI-6 device
SMP: AP CPU #3 Launched!
da2: Serial Number WD-WCC4EKKD0FU7
da2: 600.000MB/s transfers
da2: Command Queueing enabled
da2: 3815447MB (7814037168 512 byte sectors: 255H 63S/T 486401C)
SMP: AP CPU #4 Launched!
da2: quirks=0x8<4K>
da3 at mps0 bus 0 scbus0 target 3 lun 0
da3: <ATA WDC WD40EFRX-68W 0A82> Fixed Direct Access SCSI-6 device
da3: Serial Number WD-WCC4EFSNC01L
SMP: AP CPU #5 Launched!
da3: 600.000MB/s transfers
da3: Command Queueing enabled
da3: 3815447MB (7814037168 512 byte sectors: 255H 63S/T 486401C)
da3: quirks=0x8<4K>
da4 at umass-sim0 bus 0 scbus8 target 0 lun 0
da4: <SanDisk Extreme 0001> Removable Direct Access SCSI-6 device
da4: Serial Number AA011001140339330562
da4: 40.000MB/s transfers
da4: 30533MB (62533296 512 byte sectors: 255H 63S/T 3892C)
da4: quirks=0x2<NO_6_BYTE>
da5 at umass-sim1 bus 1 scbus9 target 0 lun 0
da5: <SanDisk Extreme 0001> Removable Direct Access SCSI-6 device
da5: Serial Number AA011001142318180585
da5: 40.000MB/s transfers
da5: 30533MB (62533296 512 byte sectors: 255H 63S/T 3892C)
da5: quirks=0x2<NO_6_BYTE>
Timecounter "TSC-low" frequency 1700032512 Hz quality 1000
GEOM: da5: the primary GPT table is corrupt or invalid.
GEOM: da5: using the secondary instead -- recovery strongly advised.
Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201501301837 []...
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
ipmi0: IPMI device rev. 1, firmware rev. 1.42, version 2.0
ipmi0: Number of channels 2
ipmi0: Attached watchdog
ipmi1: <IPMI System Interface> on isa0
device_attach: ipmi1 attach returned 16
wbwd0: HEFRAS and EFER do not align: EFER 0x4e DevID 0x00 DevRev 0x00 CR26 0x00
vboxdrv: fAsync=0 offMin=0x1f5 offMax=0xe64
GEOM_ELI: Device gptid/dc952a0c-a84d-11e4-866f-0cc47a30081e.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI: Crypto: hardware
GEOM_ELI: Device gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli created.
GEOM_ELI: Device gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli created.
GEOM_ELI: Device gptid/dd98f031-a84d-11e4-866f-0cc47a30081e.eli created.
GEOM_ELI: Device da1p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Device da2p1.eli created.
GEOM_ELI: Device da3p1.eli created.
GEOM_ELI: Device da0p1.eli created.
mps0: IOC Fault 0x40002622, Resetting
mps0: Reinitializing controller,
mps0: IOCCapabilities: 1a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,MSIXIndex,HostDisc>
mps0: mps_reinit finished sc 0xffffff8000a96000 post 2 free 1
da1: <ATA WDC WD40EFRX-68W 0A82> s/n WD-WCC4EFSNC01L detached
da3: <ATA WDC WD40EFRX-68W 0A82> s/n WD-WCC4EKKD0FU7 detached
GEOM_ELI: g_eli_read_done() failed gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=181235404800, length=131072)]
GEOM_ELI: g_eli_read_done() failed gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=181235539968, length=131072)]
GEOM_ELI: g_eli_read_done() failed gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=270336, length=8192)]
GEOM_ELI: g_eli_read_done() failed gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=3998638940160, length=8192)]
GEOM_ELI: g_eli_read_done() failed gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=3998639202304, length=8192)]
GEOM_ELI: Crypto WRITE request failed (error=6). gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli[WRITE(offset=181235200000, length=65536)]
GEOM_ELI: g_eli_read_done() failed gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=181235675136, length=131072)]
GEOM_ELI: g_eli_read_done() failed gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=181235810304, length=131072)]
GEOM_ELI: Crypto WRITE request failed (error=6). gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli[WRITE(offset=181235134464, length=65536)]
GEOM_ELI: g_eli_read_done() failed gptid/dc952a0c-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=181236891648, length=65536)]
GEOM_ELI: g_eli_read_done() failed gptid/dc952a0c-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=270336, length=8192)]
GEOM_ELI: g_eli_read_done() failed gptid/dc952a0c-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=3998638940160, length=8192)]
GEOM_ELI: g_eli_read_done() failed gptid/dc952a0c-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=3998639202304, length=8192)]
GEOM_ELI: g_eli_read_done() failed gptid/dc952a0c-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=181240135680, length=4096)]
GEOM_ELI: g_eli_read_done() failed gptid/dc952a0c-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=755983912960, length=4096)]
da2: <ATA ST4000VN000-1H41 SC44> s/n Z302C893 detached
GEOM_ELI: g_eli_read_done() failed gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=181236080640, length=131072)]
GEOM_ELI: g_eli_read_done() failed gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=181236215808, length=131072)]
GEOM_ELI: g_eli_read_done() failed gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=270336, length=8192)]
GEOM_ELI: g_eli_read_done() failed gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=3998638940160, length=8192)]
GEOM_ELI: g_eli_read_done() failed gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=3998639202304, length=8192)]
GEOM_ELI: Crypto WRITE request failed (error=6). gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli[WRITE(offset=181235875840, length=65536)]
GEOM_ELI: g_eli_read_done() failed gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=181236350976, length=131072)]
GEOM_ELI: g_eli_read_done() failed gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli[READ(offset=181236486144, length=131072)]
GEOM_ELI: Crypto WRITE request failed (error=6). gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli[WRITE(offset=181235810304, length=65536)]
GEOM_ELI: Device gptid/dc952a0c-a84d-11e4-866f-0cc47a30081e.eli destroyed.
GEOM_ELI: Detached gptid/dc952a0c-a84d-11e4-866f-0cc47a30081e.eli on last close.
GEOM_ELI: Device gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli destroyed.
GEOM_ELI: Detached gptid/dcec56a9-a84d-11e4-866f-0cc47a30081e.eli on last close.
GEOM_ELI: Device gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli destroyed.
GEOM_ELI: Detached gptid/dd448ef5-a84d-11e4-866f-0cc47a30081e.eli on last close.
2. pciconf -lv
hostb0@pci0:0:0:0: class=0x060000 card=0x080415d9 chip=0x0c088086 rev=0x06 hdr=0x00
vendor = 'Intel Corporation'
class = bridge
subclass = HOST-PCI
pcib1@pci0:0:1:0: class=0x060400 card=0x080415d9 chip=0x0c018086 rev=0x06 hdr=0x01
class = bridge
subclass = PCI-PCI
pcib2@pci0:0:1:1: class=0x060400 card=0x080415d9 chip=0x0c058086 rev=0x06 hdr=0x01
class = bridge
subclass = PCI-PCI
none0@pci0:0:20:0: class=0x0c0330 card=0x080415d9 chip=0x8c318086 rev=0x05 hdr=0x00
class = serial bus
subclass = USB
ehci0@pci0:0:26:0: class=0x0c0320 card=0x080415d9 chip=0x8c2d8086 rev=0x05 hdr=0x00
class = serial bus
subclass = USB
pcib3@pci0:0:28:0: class=0x060400 card=0x080415d9 chip=0x8c108086 rev=0xd5 hdr=0x01
class = bridge
subclass = PCI-PCI
pcib5@pci0:0:28:2: class=0x060400 card=0x080415d9 chip=0x8c148086 rev=0xd5 hdr=0x01
class = bridge
subclass = PCI-PCI
pcib6@pci0:0:28:3: class=0x060400 card=0x080415d9 chip=0x8c168086 rev=0xd5 hdr=0x01
class = bridge
subclass = PCI-PCI
ehci1@pci0:0:29:0: class=0x0c0320 card=0x080415d9 chip=0x8c268086 rev=0x05 hdr=0x00
class = serial bus
subclass = USB
isab0@pci0:0:31:0: class=0x060100 card=0x080415d9 chip=0x8c528086 rev=0x05 hdr=0x00
class = bridge
subclass = PCI-ISA
ahci0@pci0:0:31:2: class=0x010601 card=0x080415d9 chip=0x8c028086 rev=0x05 hdr=0x00
class = mass storage
subclass = SATA
none1@pci0:0:31:3: class=0x0c0500 card=0x080415d9 chip=0x8c228086 rev=0x05 hdr=0x00
class = serial bus
subclass = SMBus
none2@pci0:0:31:6: class=0x118000 card=0x080415d9 chip=0x8c248086 rev=0x05 hdr=0x00
class = dasp
mps0@pci0:2:0:0: class=0x010700 card=0x069115d9 chip=0x00861000 rev=0x05 hdr=0x00
vendor = 'LSI Logic / Symbios Logic'
device = 'SAS2308 PCI-Express Fusion-MPT SAS-2'
subclass = SAS
pcib4@pci0:3:0:0: class=0x060400 card=0x080415d9 chip=0x11501a03 rev=0x03 hdr=0x01
vendor = 'ASPEED Technology, Inc.'
device = 'AST1150 PCI-to-PCI Bridge'
class = bridge
subclass = PCI-PCI
vgapci0@pci0:4:0:0: class=0x030000 card=0x080415d9 chip=0x20001a03 rev=0x30 hdr=0x00
device = 'ASPEED Graphics Family'
class = display
subclass = VGA
igb0@pci0:5:0:0: class=0x020000 card=0x153315d9 chip=0x15338086 rev=0x03 hdr=0x00
class = network
subclass = ethernet
igb1@pci0:6:0:0: class=0x020000 card=0x153315d9 chip=0x15338086 rev=0x03 hdr=0x00
class = network
subclass = ethernet
