I'm using 9.3 x64 and I'm trying to get my Brocade BR-1020 10GbE card working.
Looking at /var/log/messages
The output from pciconf shows it's there:
The card is the same as the QLogic BR-1020 (QLogic bought Brocade and rebranded their cards) which is in the supported list https://www.freebsd.org/releases/9.3R/hardware.html.
I have tried using the tunable isp_load="YES" but to still no avail.
Any ideas? Help would be appreciated. Thanks.
pcib2: <ACPI PCI-PCI bridge> irq 19 at device 3.0 on pci0 pcib2: <ACPI PCI bus> on pcib2 pcib2: <serial bus, Fibre Channel> at device 0.0 (no driver attached) pcib2: <serial bus, Fibre Channel> at device 0.1 (no driver attached) pcib2: <network, ethernet> at device 0.2 (no driver attached) pcib2: <network, ethernet> at device 0.3 (no driver attached)
none2@pci0:2:0:0: class=0x0c0400 card=0x00141657 chip=0x00141657 rev=0x01 hdr=0x00 vendor = 'Brocade Communications Systems, Inc.' device = '1010/1020/1007 10Gbps CNA' class = serial bus subclass = Fibre Channel none3@pci0:2:0:1: class=0x0c0400 card=0x00141657 chip=0x00141657 rev=0x01 hdr=0x00 vendor = 'Brocade Communications Systems, Inc.' device = '1010/1020/1007 10Gbps CNA' class = serial bus subclass = Fibre Channel none4@pci0:2:0:2: class=0x020000 card=0x00151657 chip=0x00141657 rev=0x01 hdr=0x00 vendor = 'Brocade Communications Systems, Inc.' device = '1010/1020/1007 10Gbps CNA' class = network subclass = ethernet none5@pci0:2:0:3: class=0x020000 card=0x00151657 chip=0x00141657 rev=0x01 hdr=0x00 vendor = 'Brocade Communications Systems, Inc.' device = '1010/1020/1007 10Gbps CNA' class = network subclass = ethernet
