SOLVED What is the purpose of a Dupont 2.5 2X4Pin Power Cable on a mini sas breakout?
Keven
hi, i was looking to buy some cheap SFF-8087 mini-sas to 4x sata breakout cable on ebay and found some that have a fifth connector. i found that it is a Dupont 2.5 2X4Pin Power Cable, but i don't know it's purpose.
I'd like to know what is it's purpose?
What it is use for?
If it make a difference vs having a cable without the fifth cable (Dupont 2.5 2X4Pin Power Cable) for an LSI SAS 9210-8i 8-port and some sata HDD?
Samuel Tai
That's for a controller-specific sideband channel. See https://doc.xdevs.com/doc/Seagate/SFF-8448.PDF. Typically this is for things like the controller sending power on/off signals to the drive before hot-swap, or LED flash to identify a specific drive on a backplane.
Keven
Samuel Tai
Correct. If you're not using a backplane with a sideband connector, or your controller doesn't have sideband capability, this cable will be superfluous. The only impact will be on airflow cooling in your case.
Keven
Thank you for your quick reply
