rslocalhost
- Jan 1, 2018
As recommended in another thread, I bought an LSI SAS9211-8I card to burn-in test my SAS drives in a non-production machine. This card has two internal x4 SFF8087 Mini-SAS connectors. So I looked around for a cable (it doesn't come with any) that converts the SFF8087 to a SAS connector (29 pin). I found this cable on amazon.
After flashing the card to JBOD/IT mode, the cable arrived. I plugged in the 2 SAS drives I wanted to test, and they weren't found. A quick bit of investigating found they weren't spinning (platter drives, not SSD). So no power. I checked the connections, trying unplugging and replugging, even tried the other unused arms. Still no power. For kicks, since I can plug a SATA drive into a SAS connector, I tried that. The SATA drive spun.
I looked at the drives, and the SAS drives do need slight more amps then the SATA. So I figured since the system I was using was a Dell desktop, and Dell power supplies aren't the greatest IMHO, I moved to one machine that had a $100 power supply (not Dell, Antec). Same results.
So, is the cable bad or is there something else I'm missing? Cable looks in great shape, so don't see how that could be bad, but short of another answer...
